Ibpointless2 Crystal Cells
triffid
triffid
Epsom salts and cat litter?Who would have thought?
triffid
triffid
I went out to the store tonight to see if I could find the right kitty litter and cleaning powder.I find neither one but I found something else that
contained everything I wanted.In the spice area I found "Balls fruit-fresh produce protector".It contains vitamin C,citric acid,and silicon dioxide.
Its used to keep fruit fresher,longer.It prevents browning and protects flavor.Cost about $5.00.kitty litter was $2.49 on up to over ten dollars.
triffid
PhiChaser
Quote from: Peanutbutter29 on March 21, 2012, 04:05:40 PM
But, one of the Phicells AND the Superheated in series and I have some light!!!  (open circuit) 3.2v .....(in operation) 1.65v @ 600ua (.6ma).   I did this because I knew the superheated could supply the larger current, even though it would be limited to the Phicell current.
I need a joule ringer
Congrats! I need to build a joule theif at the very least... A ringer too...
@ triffid: I think the cat litter would take care of any stray H2O for sure. It is made to grab liquid right? Maybe with the right amount of water you could make a paste that could harden in the oven? I'm gonna go mix a baseline and leave one alone and charge one from the start with both my 6v lantern batteries in parallel. I will have to scavenge some carbon from another cell (or poke around my still messy workspace and maybe get lucky heh)... How many days to leave hooked up? Until the 6 volt batteries are down to under a volt? A week? The can doesn't actually say how long it takes to dry other that it 'depends on size, humidity, and temperature'. Oh yeah, the can also says 'Avoid ingestion' so I guess non toxic wasn't really ever an option if we are using salts like these or silica (or most of our other ingredients heh heh).
Happy experimenting!
PC
EDIT: Alright, I finally got some plain 'ol Durhams watter putty in the ice cube trays just a bit ago, one full sized cell that I hooked up right away, the leads already hooked to the batteries in parallel. The second was a half sized cell because I just used the 1:3 mix and that is what I ended up with heh heh... How long to leave that cell hooked up do you guys think?
Anyhow, I gotta get ordering some carbon rods or tubes or something, scavenging materials from existing projects sux...
