0 Members and 23 Guests are viewing this topic.
Note how the focus of Rosemary's idiocy has shifted. This thread is no longer about proving her assertions, it is about ME proving that HER assertion about my HEIGHT is wrong.
Why doesn't she simply answer my questions and address my points? What's the green trace representing, what are her explanations of the items I ask about on the scope trace, what about "PER", and so on and so forth. She won't address any of these substantive points with references TO PROVE ME WRONG, she simply compares me to Hitler, maligns my moustaches as if I were Hercule Poirot, and makes idiotic assertions about my height. How tall is Stephen Hawking, I wonder? And does it have anything at all to do with anything at all except his wardrobe?
What's the green trace supposed to represent, Rosemary? You are right about one thing: I will continue to attack your lies and mistakes one by one if necessary, until you correct and retract them, I die, or Stefan closes this thread. You want it to stop: THEN CORRECT YOUR ERRORS and stop lying.
What's the green trace?
poynt99
Quote from: Rosemary Ainslie on March 24, 2012, 11:03:18 AM
POYNTY.  What are you saying?  I've just checked on our apparatus.  Typically the signal probe is applied to gate of Q1 and the the terminal to the gate of Q2.  The demo included considerably more than was contained in the video.  And the shunt was most certainly NOT in that loop.  We showed that ONLY for the duration of filming because we were trying to accommodate no less than 8 'clip' positions on a limited space available - to run two scopes simultaneously.  Give me a break here.
Rosie
Rosemary,
I spent considerable time tracing out the top and bottom connections of the proto-board shown in the video. The labeling and accompanying schematic are accurate per what was shown in the video demonstration.
Quote from: poynt99 on March 24, 2012, 11:02:18 AM
If you look closely at the underside, you will see that only 4 resistors are "bussed" together to comprise the 0.25 Ohm CSR. They are presumably 1 Ohm resistors. The 5th 1 Ohm resistor does not appear to be connected. There is some writing underneath designating what that other 1 Ohm resistor is for, but I can't make it out. One end of it doesn't appear to be connected to anything.
I was not able to find a 0.5 Ohm resistor in series with the FG either, but I included it because Rosemary's original circuit diagram showed it, and it doesn't make any difference if it was there anyway. I assumed they measured the FG cable and it was 0.5 Ohm (not unreasonable since it looks like light coax), and that is another reason I included it.
.99
It was my impression that the fifth resistor was connected on the top surface of the board. If it's not... why is it there at all?
Regardless... going back to your "other" forum thread looking for your analysis, I found some very interesting analysis from humbugger about these resistors and all the stray inductances and wiring. Reply #246, you-know-where. Of course that is preaching to a choir here and it's something that Rosemary hasn't the wit to understand.
Do you really REALLY think they measured the resistance of the cable? With what? They haven't shown the competence necessary to measure a small resistance with a DMM, and I don't see any other resistance measuring gear around.
poynt99
Quote from: TinselKoala on March 24, 2012, 11:12:56 AM
My ETA from above:
QuoteETA: My guess is that they started with the intention of using a 1 Ohm shunt, and left it there unconnected in case they wanted to go back after moving to the 0.25 Ohm shunt.
It's the ONLY logical explanation. Yes, they DO have a Fluke meter there on hand. Either they measured it, or assumed it would be about that amount.
Quote from: poynt99 on March 24, 2012, 11:08:42 AM
Rosemary,
You see... now she's claiming that the Q1-Q2 diagram is correct for the video, when the diagram IN the video and the presenter's narration both say that all the mosfets are strictly parallel. I think that they didn't know AT THE TIME OF THE VIDEO that the error had been made. Yet now she claims it is always done that way.
Just so I can get on with my OWN work... since I have mosfets coming, I've bought batteries, gathered equipment together.... Please please please can we agree on just WHAT circuit is going to be tested?  If the claims made in the video are of some other circuit than is actually shown.... that is a bit misleading, isn't it? At least it is when I do it, according to some.
What is the circuit to be tested, please? Please give all component values like resistances and inductances, so that I can do just what Rosemary is afraid of: hook that sucker up to some real power measuring equipment, some integrating oscilloscopes, and do some battery drawdown  tests that WILL stand up in the court of SCIENCE.
Please give me the exact circuit of this open-source device so that I can test it for myself. Include the specs for all those clipleads too, because that's where the oscillations are likely coming from. Oh... and what kind of Paint is that on the board? Is it OK if I use a different color? Like maybe GREEN?
What are the frequency (this much I already know), the amplitude, and the offset settings of the INSTEK function generator? Am I going to have to purchase this economy-line 220 dollar instrument to supplement my laboratory-quality, calibrated, Interstate F43? For which, by the way, I paid nearly 300 dollars-- for a twenty year old USED instrument -- plus a 200 mile drive to pick it up, because of its discrete component construction and bulletproof circuitry.
