Re the use of the function generator: I say, LET HER USE IT. There is no need for a special 555 timer circuit that may make it difficult for her to achieve her desired oscillations. (No snide remarks about how long it might have been since she's achieved her desired oscillations, please.)
Simply require that the circuit be operated in the HIGH HEAT mode, sustaining the temperature of the custom 11.11 ohm load at 190 degrees C or more, for at least 48 hours, using the reduced battery pack of 36 volts, 60 Amp Hours. Since the circuit has been shown to draw somewhere between 1.5 and 2.5 amps in this mode, or maybe even more, a 48-hour run should, if Rosemary is right, not deplete the batteries at all. OTOH, if Rosemary is wrong, the run will use up all or most of the battery's capacity.
Then do the Dim Bulb test comparing the run batteries with the three set-aside batteries. Whichever set goes out first..... loses.
Anybody want to start a betting pool on the outcome? Guess the duration, buy a minute for ten dollars, closest guesser gets the pot.
I have already bought 0 minutes, and 1 minute.
WilbyInebriated
Quote from: TinselKoala on April 05, 2012, 12:45:21 PM
Is stupidity criminal?
if it was, they would have locked you away a long time ago for failing diffy equations 5? times...
Quote from: WilbyInebriated on April 05, 2012, 03:05:13 PM
Get your facts straight, troll. I failed it twice, passed it the third time. Some would argue that that  makes me even more stupid than you... some might not. How many times did Rosemary Ainlsie take it before she passed? Oh... that's right... none, she didn't even pass algebra 1 in high school. One of the fails was because I ditched the final exam in order to complete a 500 km solo flight -- the so called "diamond distance" flight of the FAI -- in a sailplane. That's REAL free energy, solar powered all the way.
All of which has absolutely nothing to do with the issues at hand, does it Wilby troll. It is Rosemary's stupidity that is at issue here, not mine, or haven't you been following?
The original mistake in the COP>17 555 timer duty cycle
The mistake in wiring the current apparatus
The mistake in the several circuit diagrams
The calculation of 25.6 megaJoules
The mathematical meaning of PER
The provenance of the VIDEO and her disavowal of it
The statements she made about her scope shots I posted
The latest gaffe of the different YET AGAIN circuit diagrams
The "endorsements" of Glen, Powercat, and Prof. Kahn
The failure of ANYONE to replicate and support her claims
And last but not least, your own failure to contribute anything of value to the discussion of the topic:
WHY WON'T ROSEMARY PERFORM THE SIMPLE BATTERY TESTS THAT WE HAVE BEEN WAITING FOR for ten years or more?
Want to buy a minute? "infinite" is still available, I think......
WilbyInebriated
Quote from: TinselKoala on April 04, 2012, 05:46:01 PM
is there enough detail in my videos for one skilled in the art to do it for themselves? Yes, there is. In Rosemary's? No, there is not.
Quote from: MileHigh on April 04, 2012, 08:35:32 PM
Then Poynt carefully watched your clip and reverse-engineered the circuit and discovered that you were not showing the correct diagram in your paper and as a result the "secret was revealed."
am i the only one who sees the GLARING CONTRADICTION here? why is tinselkoala/alsetalokin accusing poynt99 of not being skilled in the art? why is he posting complete falsehoods?
will you please come back to reality and at least show some integrity?
WilbyInebriated
Quote from: TinselKoala on April 05, 2012, 03:24:51 PM
then why did you bring it up?
probably for the same reasons you won't perform that simple public mea culpa you owe me...
