0 Members and 23 Guests are viewing this topic.
poynt99
Considering the amount of noise present due to the oscillation, yeah it would be possible for the Gate to pick that up I guess. You'd probably need only a 1M or so pull-down to prevent that. Or perhaps only a few hundred pico-Farads of capacitance would do the trick?
poynt99
TK,
Your video demoing the FG offset and affect on the oscillation modes was a good one. Clearly one can see when the offset is changed from one extreme to the other, the circuit goes from normal switching mode, to burst oscillation mode. Well done ;)
.99
Rosemary Ainslie
Quote from: TinselKoala on April 07, 2012, 06:40:19 AM
Basic FG offset function:
http://www.youtube.com/watch?v=xoYFxq4bm2w
You all have no idea how hard it is to fake this stuff. I had to use CGI and a room full of renderers to pull this one off.
Not true TK.  All you used was the magical misapplication of a light switch. The trick is to turn it on.
Quote from: TinselKoala on April 07, 2012, 06:40:19 AMOH... it's almost six am. I've got to hurry.... it's almost time for me to reset the ROSIE TEST PREVENTION broadcast device, which radiates Tesla technology longitudinal scalar waves that keep Rosemary from thinking coherently and performing a TEST of her batteries for yet another day. I'm going to be boosting the power soon, though, so that a single linecast will prevent her from testing for an entire week.
I'm not sure that this is being correctly focused.  I have absolutely NO say as to when I'll be allowed to run these tests.
Quote from: TinselKoala on April 07, 2012, 06:40:19 AM(The grubby nails are because I spent literally _all day_ Friday replacing my car's air conditioning system. I vacuumed the residual R-22 out, replaced the compressor, condenser, accumulator, orifice tube with new parts, flushed the evaporator and hoses with dl-limonene followed by compressed air, replaced the  highside switch, the compressor-mounted switch and all the Schreder valves, all the o-rings, changed the fittings to R-134a standard, vacuumed out the system for a couple of hours with a 2-stage pump, recharged with 8 oz oil and 32 oz R-134a--- and now I have blissfully cold air blowing out the airholes in the cabin. And I still found time to re-actuate the PoserPreventer.)
I would strongly recommend that you just wash your hands.  It usually does the trick.
Rosie Pose
I see that Rosemary still hasn't discovered my hiding place for all my TarBaby test reports. I hide stuff pretty well, don't I? Kind of like in "The Purloined Letter." Also my Tesla NERD preventer is working quite well-- it has even stopped the NERDs from discussing testing at all.
Meanwhile, I've posted... er, sorry, HIDDEN yet another report about Tar Baby here:
http://www.youtube.com/watch?v=HpqqEefYENU
And.... who ever said ("claimed" as Ains-lie says) Tar Baby was a "replication" of the NERD device? I have explicity said that it is not, and that the only CLAIM I make about Tar Baby is that it performs the same as the NERD circuit (whichever one, I don't care, I've done them all.)
Just because it uses the SAME circuit diagram, the SAME mosfets, the SAME current viewing resistor, the SAME gate drive input signals, the SAME load resistance and impedance (give or take) and makes the SAME heat in the load and the SAME oscilloscope traces as the NERD device.... it cannot be a replication, because it cannot charge its own batteries. QED.
Just like when I replicated Mylow's hoax motor: I did it just like he did, but Sterling wouldn't give me the award, even though he acknowledged my priority--- because MY replication wasn't overunity so it couldn't be a replication, even though the oriiginal wasn't ou either and mine was powered the same as his..... go figure.
So, apparently the only thing that counts as a replication is being able to CONFIRM THE CLAIMS made about the original. Parts, construction, operation, data, none of that matters... only the CLAIMS count.
Quote from: Rosemary Ainslie on April 07, 2012, 09:12:53 PM
Heh.... are you hallucinating again? It seems that other people can see just fine what that video shows.
NOTE WELL: Somebody else is in control of Rosemary's testing.... I wonder who and why.  When she'll be ALLOWED to run tests. NO SAY.
Rosie Pose
Said by someone who has never done a lick of hard grubby manual work in her life. My grubby hands mean that I saved several hundreds of dollars on that job AND wound up with several useful tools, like a vacuum pump and a gauge manifold set. I worked for years as an aircraft mechanic, overhauling engines, and believe me, no amount of soap and scrubbing will get your hands clean. Time is the only thing that will do it, as the dirty skin wears away and is replaced by fresh. Washing your  hair with dishsoap is also a good way to clean your hands.
Or you can just pay somebody else to do your dirty work. Try that after the apocalypse, though.
