Rosemary Ainslie
My Dear Poynty Point.
What you need to do is make ALL your sim information available.  Else no-one will ever give any credibility to any of your findings ever again.  Surely you KNOW THIS?  If you were in the LEAST bit interested in promoting studies in over unity - then you should be falling over your feet in your anxiety to explain how this simulation is done.  Even if it's simply to explore that strange oscillation.  And?  Strangely you're not?  In fact you're ACTIVELY promoting their disengagement?  Why is that?
You've proposed multiple reasons why the oscillation is happening at all.  This includes incorrect probe positions - the fact that a battery applies a negative current flow when it discharges it energy - the fact that the battery can discharge its energy straight across the gate of a MOSFET and bypass it's own source.  Alternatively that it can run a course right through the ground terminal and into the signal probe and across an applied negative signal.  You've proposed that our measurements are erroneous as they apply to the position of the current sensing resistor - to the miscalculation of the applied impedance value - and even to the fact that those resistors have inductance associated with them. Which is correct - by the way (BTW) BUT not that it makes the slightest bit of difference to our results.  You've suggested that the battery can discharge its energy in a 'one step' 'two step' dance step - as it chooses which MOSFET gate to use.  But you stopped that argument short of explaining why then the waveform was not 'purely positive'.  You've relied on arguments related to my ignorance, duplicity, stupidity, antiquity, vacuity, lunacy and general absurdity.  You've accused our collaborators variously of being 'morons' or untrained in matters scientific - or not existing at all - as they WISELY defer from posting on these forums.  And all this while you seriously proposed that we re-write our standard model in line with that rather absurd 'paper' that you ventured where your counterarguments were confined to a poor little academic who was relegated to the sidelines and only allowed to express astonishment at your revisionary visions.   Not to mention your heavy subscription to my 'hate blog' where you state what you like freed from all editorial constraints unless they're either 'positive' or 'on track'.
You relied on that sim evidence to disprove EVERYTHING.  The problem with all sims is that its an easy path for the most of you trained in electronics to quickly test all this - as Flux It explained.  Now.  Once that starts on forum - as I'm well aware of it happening 'off' forum - then more and more people will start duplicating that OSCILLATION that you and your 'friends' advised us had no relevance.
And you and I both know that there is no explanation within the standard model for that waveform.  But it's fully explained with a minor extension to Faraday's Lines of Force.  Which is what we propose.  For some reason ANY THEORY is preferred over this?  I wonder why that it?  Could it be that it will actually ASSIST in this DRIVE to energy efficiency?  Maybe?  GOLLY.
So.  WHY POYNTY POINT are you on the wrong side of this drive of ours?
Kindest as ever,
Rosie
Rosemary Ainslie
And may I add this.  A certain Dr Vest relied on an MIT replication of cold fusion to DISPROVE COLD FUSION.  He thereby managed to endorse legislation that prevented ANY PATENTS CLAIMING ANYTHING AT ALL RELATED TO COLD FUSION.  Which is why they invented various alternate terms including Low Energy Nuclear Reaction.  He managed to prevent this being developed in America.  Unfortunately he did NOT manage to prevent its development elsewhere.
There's a moral to this Poynty Point.  I trust you see it.  DISPROOF NEVER CUTS IT.  When there's new evidence - and when the 'cat's out the bag' so to speak - then there will ALWAYS be further and further testing. Thank God.  You cannot put a LID on experimental evidence and experimental claims.  And it only needs ONE SINCERE REPLICATION - to PROVE ANYTHING AT ALL - in science.  The best you can rely on is to continue to discredit me.  And I welcome it.  The more so as your OVER reliance on this rather starts to beg the question.
Regards,
Rosemary
edited you're to 'your'
poynt99
For the following reasons, I don't see the need to post all my simulations again:
1) They've been posted in this thread to some degree, and in your "demonstration" thread also on this forum. There is also a document posted that goes through the measurement analysis. So it's all here already.
2) No one here is asking for these simulation posts, except you. And you've already seen them all.
I'm sure the 3 readers here are much more keen on seeing my actual test results, as they'll be much more convincing than the simulation.
Flux It
I would love to see test results, and the simulation was much more of a visualization tool, as I am not implying any accuracy of its results. But the simplicity of the simulator makes an excellent design tool that anyone can use to post a circuit example. Personally looking back to find circuits and test results in this topic is like watching a boxing match in slo mo ;)
Not taking any sides, I just think there should be more solid information. Will you be using a 555 in your tests?
Rosemary Ainslie
Quote from: Flux It on March 06, 2012, 09:12:56 AM
Flux It.  The simulation is EXTRAORDINARY.  Simply because it is able to compute a negative wattage - which, as explained, is anomalous - at its least.  But what is really odd is that the sim can allow for that 'above ground' voltage.  From what I saw of Schubert's sim - it gives a result that was more or less predicted by Poynty.  However, Poynt's own sims are able to replicate that waveform.  Either the sim is assuming a discharge from the battery supply - or it's allowing 'logically' for the development of CEMF to run both halves of each oscillation waveform.  If the former - then there SHOULD be a path from the battery supply to allow for that positive half.  And we none of us can find that path.  It is most certainly NOT a conventional path through the Gate at Q2 - because if it was - then it would need to bypass the Q2 source leg.  And if it's allowing for the path from CEMF to run both halves of the oscillation then the question is 'how does this compute with the standard model?'.  Because CEMF  should only result from 'stored energy' - at best.
Also.  If we simply parallel the transistors - in the usual way - then we don't get the oscillation at all.  My own guess is that the sim software simply applies inductive laws which kick in when each oscillation reaches its peak.  Which means that they've only used INDUCTIVE LAWS.  And that still leaves one with the need to resolve the polarity.  It's not straight forward.
In any event.  Poynty and others have got my paper.  If you want 'results' I'll be glad to forward this to you.  Just email me or PM me with your email address and I'll forward them.
Regards,
Rosemary
