Video On line, Proof Of Overunity With Permanent Magnets, LaFonte Research
Started by gammarayburst, November 29, 2011, 10:26:24 PM
lumen
I have done fairly extensive work along these lines so I will attempt to explain why this does not work.
The reason the chain would try to separate is because the metal becomes a magnet that repels the nearby link that also becomes a magnet under the field of the primary magnet.
The problem is that the nearby links cannot become as magnetic as they would become if they were a single link because the nearby link prevents it by being of the same polarity. So as it separates, the metal becomes more attracted to the primary magnet than when it was close together.
With some steel rails in a < , the magnet will attract more to the wider area. at least to the point where the metal becomes the most transformed into a magnet itself.
Low-Q
I have some iron wire that I can shape like that and see how the magnet will respond to that shape.
Vidar
gammarayburst
See attached drawing and I will be posting proof of concept video's tonight and post links. The design has a 90 degree repulsion mode and then switches to a 90 degree attraction mode. Then starts the cycle again. Switch aspect tested in video as well as repulsion and attraction modes.
Butch LaFonte
The LaFonte Group
gammarayburst
The operational sequence of the switcher in the Pseudo Solid LaFonte Group Motor/Generator has been changed. See attached drawing.
Butch
