overspeed danger bike wheel
Started by jesso, January 22, 2012, 04:59:02 PM
jesso
This is another easy to build example of easy destruction possible by true overunity. This a a bike wheel but on the rim you put a circuit of pvc tubing cut every 4 inches or so most of the way thru, going around the whole wheel with a wire in the middle to pull it all tight around the rim. The tire is in place with the pvc as this occurs, and with the tire seated down into plact the bike with good brakes is ridden on and speeds up. I was clocked by a c.h.p. at over 70 miles per hour speed going up a long slow grade I couldn't ride for miles like that and not get completely tired. All I did was pedal a little, in lowest gears if I have that much right about bikes. If it overspeeds it levitates and can carry away bridges and hurt airplanes, possibly.
You're pretty funny. Where's the video of your levitating bicycle? A photostat of your speeding ticket from the CHP?
8)
Cloxxki
I am sorry to inform you that I made this same invention around 2 years ago. In fact, I am close to a patent grant.
Actually I found it most practical to bring the outer shape of the device down to that of a classic broom.
jesso
I did not get a speeding ticket.  Get a person of the opposite sex and try this: dizzilly off-balanced sex-saved in-touch. A kind of breatheing can help get the dizziness. Have your tongue hold your body upward and backward after you inhale some air. Both do this and the other directions and you should be set for some real good fun!
e2matrix
did you forget to take you meds there jesso....  reality is slipping away on you.  LOL   Really ... do you expect someone is going to believe this here.  At least show us a video.  That'll baffle some people for a while.
