Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
e2matrix
Quote from: poynt99 on February 08, 2012, 02:38:14 PM
Well, the simulation was first done by Ali, then he built the circuit afterwards. At least that is my understanding.
Now, as we've not seen evidence of this circuit actually working on the bench, it is prudent at this time to analyse how the circuit is operating, and IF indeed there is something weird going on in the simulation, OR if there is something being overlooked. There IS a claim that the simulated circuit is exhibiting OU, so the purpose of having a working circuit in ORCAD is so that I may determine if this claim is merited or not.
.99
I realize Ali posted the sims and I have my ideas why he did but does ORCAD or any sim actually have the ability to exhibit OU and on what basis would they exhibit OU unless it's just a glitch in programming?  Are they programmed with theories outside of the mainstream such as radiant energy input?  I doubt they are so I still question what is expected from something that is essentially like a graphing calculator of sorts.  It can't find magic unless magic was programmed into it.    I guess anything that can add to the pool of knowledge on this is good to have but I think for a circuit as easy to build as this that it might be time better spent in building it.   Anyway thanks for your input.
poynt99
Quote from: e2matrix on February 08, 2012, 06:25:50 PM
You seem to be missing the point.
It is Ali that is making the claim for OU in the simulation, not I, and it is Ali that posted the files so that others could investigate it, which I am doing. Now, you seem to have a problem with my choice to do the simulation, so I would advise you to take your issue up with Ali, not I if you don't mind.
Also, I am aware of two bench replications, and neither of them exhibit anything close to OU.
.99
hartiberlin
I think, Ali should ask his boss for a few days of vaccations from his job, go home
and finally upload the video and a few pics, so that we can see, that it is real,
what he is saying ?
Maybe he also used a iron wire coil and has the same excited radioactive decay in
his coil that we just spoke about in the Kapanadze thread and which is probably
the effect for the huge overunity COP factor ?
Regards, Stefan.
madddann
Hi guys! I've been fiddling with multisim for two days now and i cannot achieve what Ali did. I built the circuit from scratch many times in multisim 10 and multisim 11 and when i first time run the simulation it gives me an error, then the error is corrected and the circuit runs as expected by the logic - no overunity. I have no idea how Ali's 1.2 version runs withouth stopping and gives huge overunity - i tried to replace all of the components and it still runs, so I think there must be some "secret" parameter that Ali changed and allows the simulation to run overunity.
@Ali
Below I attached my multisim file - can you tell us what is the difference between this and your 1.2 version - why the simulation is different?
...this are my results from multisim 10 and 11 and both follow logic...
forest
Quote from: madddann on February 09, 2012, 04:52:34 PM
@Ali
this secret is inside mosfet and in placement and coil wind direction and in some simulation global parameters set to avoid error IMHO
look this is not important if that run for days or just 3 hours it can be not OU but very very efficient resonant circuit at resonance, the essence is it proves OU is possible in the same way the CFL bulbs could produce more light than incandescent filament ! magnetic field is free and so any kind of radio or light rays !!!!
