Thanks to ALL for your help!!
Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
gyulasun
Hi Dann,
Thanks for the simulations.  Would like you to ask when have some time, please use a third wattmeter to measure the power taken from (or to?) the capacitor C2.  The current input of the wattmeter would be inserted in series with the upper pin of C2 and the voltage input of the wattmeter would be in parallel with C2.
We might see some further info this way,  hopefully.
Thanks Gyula
Mannix
Quote from: madddann on February 10, 2012, 03:39:56 PM
If I copy paste my circuit (built from scratch) to the Ali 1.2 platform it works (overunity) as it is. The generator does not make any difference - it's output is the same. See? I attached the picture and the file.
Dann
So you already know that there is a paramater different in your simulation conditions it took 3 minutes to prove that  ..do you know which one ?
Or is this a guessing game for us ?
Of course its rational that this circuit shoud not  work in reality.   even so it is something to shoot for
Khwartz
Dann
to all:
How that changes could explain the theoretical OU here, while same components in the other set didn't give OU please?
Cheers.
madddann
Hi guys!
Today i placed the power meter for C2 and found out that at first it shows -60W but then gradualy falls to zero and floats few watts up and down.
Then i placed two power meters for C1 and L1 and found out that C1 power floats a few watts up and down but the L1 power is at constat -60W - interesting huh? So there you have the "impossible" power source.
Below I attached the two xspice log files so you can see the settings of the working and the non working version of the circuit. I fiddled with the global and other settings but had no luck and i could not find out where all of those settings are located and I dont understand what some of the settings mean, so this is for those of you more familiar with spice.
Now that everithing is more clear, I'll just wait for Ali to upload his video - my last hope that the circuit works.
edited: ...oh i see i left a ground and a wire there in the second pic, but the simulation is correct...
Dann
poynt99
dann,
I see many differences in the settings. It appears that you left all the settings as default or automatic, while Ali changed a number of them.
I suspect that Ali can't get it to work in PSpice, which is why he has not posted the files. But I think it is a moot issue anyway, since the one PSpice file he did upload (a different configuration than above) did NOT show overunity at all.
I suspect the actual problem here is either in interpreting or using the power meters in Multisim. Power can not be coming from "nowhere".
.99
