Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
Ghazanfar_Ali
@duff
Ok friend. Have u catered for load resistance. he capacitor in your cct discharges soon u connect the load. I think your load is less than 150 Ohms. Try to check the resistance of the bulb and add some resistance in series so that the load should be equal or greater than 150 Ohms. I tested using two bulbs of 100W in parallel and placing this parallel pair in series with another 100W bulb. Voltage rating of each bulb was 120 Volts. Load resistance is very much important in making the 4700uF Cap to recharge again and again.
Best of Luck
be_design
@EMdevices
Ref. Schematic V1.x by Ali G.: (basically same as yours)
Yes, power from the drive is transfered, but very little
Without having done any simulation yet my self -
you may watch the Gate-Drain power with a sim.
Data for IRFP 260's Qgd charge is 110 nano coulomb (later versions have even less
charge) at 10V gate drive, which means average Igd for every other 0.5 mS would be
0.22 mA (the 150 Ohm load will dump this small charge in due time) Without doing
the full complex-impedance calc. - the average continuous signal gen. transfer to
the load from all three MOSFETs combined should then be less than 3.3mW
Now what about the opposite - loss from the load side to the gate/signal port?
Not really, looking at the charge transfers involved according to data sheets -
The scope picture shows 200V almost sine shaped for 0.32 of the time -
17.6mA average will be 'lost' to the gate in 0.125 mS, but will be recovered
into the load on the falling end of the half sine. Effectively then the internal
virtual capacitor is connected between load and reference(ground)while signal gen.
is low. So the energy here is just cycled back and used in the load.
Then the conclusion is that insignificant energy would be supplied from, or
lost to the driving circuit 'IF' say 42W average is dissipated in the load.
(looking at the scope sim-picture, shows aprox. 0.7x200x200x0.32 / 150 ~ 42W
continuous average power)
SchubertReijiMaigo
Quote@DuffThumbs up.I will suggest, just give it a try by removing 1mH in series with sig gen to ground and place a 1H inductor in series after 4700uF cap to ground. and see the strange effect. I told u this circuit is really a weird one once it started running by itself on my table. But it is definitely producing harmful radiation also. My two external HDDs were wiped off which were placed 5 meters away from the toroid. If u feel something strange later while walking or working on laptop, some off center visions, don't panic. Its just effecting your bio energy field. To be at safer side I prefer just to use some Al shield box . I am not a psychopath but strange events have been happening since then I conducted this experiment and I am astonished why it is so? Am I fiddling with secrets of nature?
You're on the good side: paranormal effect appears when your LC is self running OU
Read the whole Rotoverter Theory at EVGray Group (especially "Hector Post Volume 1 to 6") It's the "Bible" of the LCR OU transformation), a certain Hector Perez have experienced while working with high Q resonator (in his motor and transformer) these paranormal phenomena, which is in correlation with OU energy transformation...
1) High EMF pulse that fry everything around (up to miles) with big transformer.
2) Time space distortion (Time travel)...
3) Antigavity.
4) Weird effect like Philadelphia experiment...
5) The device cool down like a VTA...
6) Disease and disturbing bio field (try a healing frequency like 528 Hz) (Love and DNA repair...)
All those phenomena are side effect of energy transformation, tapping into infinite source of Nature itself...
Hector have UFO visit (Paranormal anomalies are instant detected light year away by UFO...)
MIB encounter (not friend)...
If your effect that your describe here is real, beware experiment carefully with high Q OU LCR, self-looping can be dangerous if not controlled...
High Q LC resonator are not TOY, you tap directly into the wheel-work of Nature like Tesla said...
I work on a kind of MRA (Magnetic Resonant Amplifier) which is similar to the Aligen (a self-looped, self-running, high Q resonator... )
I hope to reproduce those effect if I can get OU and loop it (Paranormal effect appear when the device is OU and self-looped...) It will be a good conformation of Hector Energy Transformation Theory...
Beware again, high Q resonator are not TOY...
Just my 2 cents on this.
SRM.
duff
Quote from: Ghazanfar_Ali on February 14, 2012, 01:21:40 AM
@duff
Best of Luck
Ali,
I am still waiting on parts (should be here today) however I do have 1 IRF260MPBF which I have been using and running  more tests.
As I'm sure your aware light bulbs change resistance with current/heat, so I've removed the 100W bulb and have been  testing with a 150 ohm resistive load.  It is not a carbon resistor and has about 173uH of inductance but it  I've run your simulation adding the inductance and it still appears to run OK.
Still nothing significant to report but again I'm only using the single MOSFET.
duff
Ali,
My circuit is fully functional again but I am still unable to run from capacitor.
Maybe I need to change my inductor to an toroid.
You stated: "I used a ready made based on ferrite toroid."
Can you provide a link to the product you used?
Thanks
Edit: Did you us an earth ground?
I have tried it both ways and noted no difference.
What happens if you do not connect a load to the circuit?
Will the voltage or current continue to build?
