Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
AbbaRue
Here is the text file for the simulator.
$ 1 5.0E-6 6.450009306485578 64 7.0 50
165 368 288 384 288 0 13.0
w 368 320 336 320 0
r 336 320 336 384 0 10000.0
w 336 384 368 384 0
w 336 384 336 416 0
w 336 416 368 416 0
c 336 416 336 480 0 1.2E-7 4.8195399334074835
g 336 480 336 496 0
r 336 320 336 256 0 10000.0
w 336 256 432 256 0
l 608 256 608 336 0 0.0050 0.38279558642927525
w 608 336 704 336 0
r 704 336 704 432 0 575.0
g 608 432 608 464 0
g 704 432 704 464 0
v 688 304 688 256 0 0 40.0 13.0 0.0 0.0 0.5
g 688 304 688 320 0
s 608 256 688 256 0 0 false
w 432 256 608 256 1
x 715 412 793 415 0 12 Load 2x 100W
x 716 425 821 428 0 12 lightbulbs in series
x 695 272 732 276 0 14 + 13V
w 544 352 560 352 0
t 560 352 608 352 0 1 0.6709557540387573 0.7273222594775242 100.0
r 496 352 544 352 0 435.0
r 608 368 608 432 0 1.4
o 6 32 0 43 10.0 0.0015625 0 -1
o 15 64 1 35 40.0 9.765625E-5 1 -1
o 12 64 1 35 2560.0 9.765625E-5 2 -1
o 12 64 0 35 1280.0 3.2 3 -1
o 22 64 0 33 2.5 0.05 4 -1
AbbaRue
@JacaP30
Your posted circuit has no output coming from the 555 timer to the Transistor.
The latest version of the simulator have added the RST pin to the 555 timer.
This pin has to be connected to the Positive input to set it high for the 555 timer to work.
When I designed this circuit they didn't have the RST pin included as you can see if you copy and paste my text.
@poynt99
I didn't calculate the power input or output, the simulator does that for you.
Clicking on the 575 Ohm resistor select "View in Scope" and select "Show Power Consumed"
It reads 1.61 kW.
And the 13V input reads 27.9 W which can also be calculated by 13V x 2.15A across the switch.
@All
Perhaps the simulator isn't really in error.
If you look at the output scope waveforms, you can see they are very short pulses with large spaces between.
The scope is reading the peak of the pulses.
But the spaces between pulses indicated that time is exchanged for voltage increase,
so it all works out even in the end.
28W of input over time is being released as a 1600W pulse.
forest
well, it's like charging cap and then ring down in tank circuit  :P energy in cap is low but oscillations in tank takes long to diminish. all is fine this is RESONANCE POWER and works with VERY STABLE LOAD
JacaP30
$ 1 5.0E-6 37.11724081536377 47 7.0 50
165 160 128 176 128 0 0.0
w 160 160 128 160 0
r 128 160 128 224 0 13800.0
w 128 224 160 224 0
w 128 224 128 256 0
w 128 256 160 256 0
c 128 256 128 320 2 8.16E-8 7.331555589896209
g 128 320 128 336 0
r 128 160 128 96 0 5200.0
w 128 96 224 96 0
l 400 96 400 176 2 0.004889999999999999 0.36718631157293774
w 400 176 496 176 0
g 400 272 400 304 0
g 496 272 496 304 0
v 480 144 480 96 0 0 40.0 13.0 0.0 0.0 0.5
g 480 144 480 160 0
w 224 96 400 96 1
x 487 112 524 116 0 14 + 13V
w 336 192 352 192 0
t 352 192 400 192 0 1 -26.640385884920914 1.939999999970189E-11 100.0
r 288 192 336 192 0 388.0
181 496 176 496 272 0 661.6251692927772 100.0 120.0 0.4 0.4
w 400 208 400 272 0
w 400 96 480 96 0
o 6 32 0 299 10.0 7.8125E-4 0 -1
o 14 64 1 299 80.0 9.765625E-5 1 -1
o 21 64 0 35 320.0 3.2 2 -1
o 21 64 1 35 640.0 9.765625E-5 3 -1
Why not light?   ;)
Flux It
Quote from: JacaP30 on February 28, 2012, 05:49:39 PM
w 160 160 128 160 0
w 128 224 160 224 0
w 128 224 128 256 0
w 128 256 160 256 0
g 128 320 128 336 0
w 128 96 224 96 0
w 400 176 496 176 0
g 400 272 400 304 0
g 496 272 496 304 0
g 480 144 480 160 0
w 224 96 400 96 1
w 336 192 352 192 0
w 400 208 400 272 0
w 400 96 480 96 0
Why not light?   ;)
Your lamp is at 120 volts and the warmup time is longer than your oscillation try this-
165 336 192 352 192 0 0.0
w 336 224 304 224 0
r 304 224 304 288 0 13800.0
w 304 288 336 288 0
w 304 288 304 320 0
w 304 320 336 320 0
c 304 320 304 384 2 8.16E-8 5.243997315932939
g 304 384 304 400 0
r 304 224 304 160 0 5200.0
w 304 160 400 160 0
l 576 160 576 240 2 0.004889999999999999 8.861926450542796
w 576 240 672 240 0
g 576 336 576 368 0
g 672 336 672 368 0
v 656 208 656 160 0 0 40.0 13.0 0.0 0.0 0.5
g 656 208 656 224 0
w 400 160 576 160 1
x 663 176 700 180 0 14 + 13V
w 512 256 528 256 0
t 528 256 576 256 0 1 -16.047444480213848 1.939999999970189E-11 100.0
r 464 256 512 256 0 388.0
181 672 240 672 336 0 254122.78869531673 100.0 12.0 0.0040 0.4
w 576 272 576 336 0
w 576 160 656 160 0
o 14 64 1 299 160.0 9.765625E-5 1 -1
o 21 64 0 35 160.0 12.8 2 -1
