Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
callanan
I think some credit should go to this guy for being the first to make a coil made of string....
Lakes
Ghazanfar_Ali
Ok for a few great scientists above. If they consider me a joker so let them be happy to admit myself that I am. And who understand my work they know I m not . Bezzel wheel was made long time ago my dear. And this forum covers solid state devices. Secondly these pics above have nothing to do with my earlier schematics. And coil is not made up of threads. If U improve ur eyesight the insulated wire is in between each turn of the thread. Thread here is just a separated to increase Q. I stopped posting my threads to avoid comments of people like U who know nothing except jeering upon others work. I never forced U to waste ur time reading my thread. Let me do my work. The people with wisdom know that my earlier cct needs just an SG to do rest of the magic. God Bless U All.
Dave45
Mr Ali I think you were right by not using an lc circuit with your primary I think this is where most have gone wrong, let me explain when current passes through the primary in one direction the fields of the primary are oriented in one direction but when collected in a cap and returned through the coil the fields are reversed, if the secondary's are wound in one direction they will recieve the energy from the primary in only that direction when the current is reversed and the fields are reversed the secondary's are not wound for that direction, so you are only collecting energy every other pulse.
By using a flywheel configuration on the primary the secondary's receive every pulse, and if your coils are in resonance they will establish a resonant lock but with alternating current you cannot establish a resonant lock because the primary is switching its fields every other pulse.
If you want to use a lc circuit on the primary you would need to wind the secondary's with a caduceus winding, this way your secondary is oriented right for the changing fields.
We will find the answer and it can be understood.
take care
keep up the fight
dave
Ghazanfar_Ali
@Dave
Thanks for an informative reply. I intentionally avoid Caduceus Coil to be used as Secondary as I worked a lot on it and this type has its strange properties. I really want to avoid Scalar waves and Temporal disturbances therefore I am working on Don Smith's technique of CW+CCW secondary with a center tap.
Kind Regards
Ghazanfar
