Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
Quote from: Ghazanfar_Ali on July 30, 2012, 10:55:53 AM
Ok for a few great scientists above. If they consider me a joker so let them be happy to admit myself that I am. And who understand my work they know I m not . Bezzel wheel was made long time ago my dear.
OK, whenever somebody brings up Besseler as "support" for their claims.... bells should ring.
And your thread title is what? It refers to a device that is NAMED AFTER YOU: a second bell should ring. And it refers to utilizing trapped energy.... well, show it being utilized. We can see that there is a lot of UNUTILIZED reactive power looping around in your tank circuit. So? Let's see you utilize it..... without additional power input AS YOU CLAIM TO BE ABLE TO DO. My dear.
QuoteAnd this forum covers solid state devices. Secondly these pics above have nothing to do with my earlier schematics.
So you post schematics of one thing, run away for months, then come back and post pictures NOT of what you started the thread with, but some other device. Like I said.... would you like to see my Etch-a-Sketch? Off topic, or not?
QuoteAnd coil is not made up of threads. If U improve ur eyesight the insulated wire is in between each turn of the thread. Thread here is just a separated to increase Q.
Do you have any idea how to increase Q? From looking at your picture, I guess not. You are indeed a joker, and perhaps a parrot as well.
QuoteI stopped posting my threads to avoid comments of people like U who know nothing except jeering upon others work.
You stopped posting because people were asking you hard questions like wanting to see your sim files and wanting to see YOUR PROMISED VIDEO of a working device.  And if you think that I know nothing of this kind of work .... then you know nothing of me.
QuoteI never forced U to waste ur time reading my thread. Let me do my work. The people with wisdom know that my earlier cct needs just an SG to do rest of the magic. God Bless U All.
Well.... you've got your Spark Gap now, don't you. SHOW IT WORKING, powering a load, DOING ITS MAGIC, without any continuing power input. Or are you no longer claiming that?
You've invented the CW radio transmitter, Ali. If you hook your "unhooked" scope probe to a piece of aluminum foil, you will pick up your oscillations even further away.
God bless U 2. And if you want Q, clean up your layout and solder those caps together. Lose the string, use Litz wire to wind your coil, wind with 2 parallel strands simultaneously, spray with Krylon to secure to form... then REMOVE one of the strands and respray. Now you will have a perfectly spaced coil with HIGH Q.
Dave45
Quote from: Ghazanfar_Ali on July 30, 2012, 01:43:49 PM
@Dave
Thanks for an informative reply. I intentionally avoid Caduceus Coil to be used as Secondary as I worked a lot on it and this type has its strange properties. I really want to avoid Scalar waves and Temporal disturbances therefore I am working on Don Smith's technique of CW+CCW secondary with a center tap.
Kind Regards
Ghazanfar
If using a cw and ccw coil as secondary's you must realize, as you have, that you cannot use a lc circuit on the primary and also that you are creating two different types of electricity that will not run with each other, the cw coil will run back to itself to complete the circuit but will not run with the ccw coil, the opposite of the same is true.
A bucking coil as the primary and two secondary's wound the same cw or ccw will create a dc system and will run from one secondary to the other to complete the circuit.
Ghazanfar_Ali
@TinselKoala
Keep ur ideas and comments with you. If u know how to increase the Q do it urself. Dont waste your time and mine writing that much long comments here where u will not get something to earn money. Get a fresh lemonade cool your upper chamber down and concentrate in your own work. I will appreciate if u get something outta my this reply.
Ghazanfar_Ali
@Dave
Joining two far ends of CCW and CW coils u get desired voltage with high amps between center tap grounded and two common ends provided u use a thick wire gauge and keep the combo tanks in resonance. But we cannot eliminate capacitance by using only inductance. Even an alone inductor is again an LC Tank circuit with very low parasitic  capacitance (usually in pF for an air core L). If u see the ringing signal I got on Oscilloscope it shows approx 8 cycles till it damps completely. Where as a rough calculation is that if I get 10 cycles in one damping function and last cycle's amplitude is 1/e times the amplitude of 1st or 2nd cycle (which is usually equal to input signal which I cant calculate due to nonavailability of high voltage probe) the Q is 10. Its less than 10 n the case of my setup so far.
Quote from: Ghazanfar_Ali on July 30, 2012, 03:06:22 PM
@TinselKoala
Demonstrate that your claims are true.
Then I'll buy you a lemonade.
If you cannot demonstrate that your claims are true..... then you buy the lemonade... and keep ur ideas and comments with you.
I will appreciate it if you demonstrate your claims.... show your "self runner"..... show your device lighting up some bulbs without continuous input power.
OR ADMIT THAT YOU CANNOT.
