Heat conversion by using piezzo effect
Started by andreas_varesi, April 11, 2005, 06:59:59 PM
andreas_varesi
I found a German patent from Michael Jennsen DE 199 42 739 A1. He uses piezzo ceramic rings with a diameter less than 0,1mm and a membrane out of noble metal. Driven by ambient temperature the gas pressure is quickly changing at the small membrane. A rectifier is used to transform the chaotic alternating current into usable direct current. At this point I fear that the voltage of the small piezzo elements is to low to overcome the threshold voltage of a normal rectifier. Has any one experience with this invention?
Thanks in advance
Andreas
betajim
As long the voltage generated by the piezo-electric element is greater than 0.6 volts the
rectifier will conduct current. Here is a neat trick that I use to demonstrate the piezo-electric
effect: take a piezo-electric buzzer element (the kind that are round brass disks) and connect
a LED to the two leads of the element. When the piezo disk is tapped (I use the eraser end
of a pencil) the LED will flash.
Take care.
Charlie Brown ARN
I imagined using nanometer scale speaker coils and magnetic slugs or pizeoelectric elements feeding bridge rectifiers to make a strong challenge to? 2LT, the widely accepted law leading to the Grey Death of the Universe, then I pared down the design to the rectifiers. To continue the persuasion, we need to optimize the geometry of the conceptual piezoelectric device to deliver a high voltage under Brownian impacts. One approach, imaginary parts costing nothing, is to use transformers. The pizeoelectric device / transformer (Brownian, mrechanical) can be replaced by a high value resistor (Johnson, electronic).? ?
Aloha, Charlie
Charlie Brown ARN
Another transducer is the elctret microphone. Electrets are permenently electrostatically polarized materials.
Going in a new direction, imagine nanoscale pillars of polarized electret material inside a diode bridging the junction. Perhaps that would bias a diode for small signal work. This has been in my idea closet for years. Thanks for letting me be comfortable enough to share it.
Aloha, Charlie
andreas_varesi
Hi Charlie,
the idea using an electret for bridging the threshold voltage of a diode is great. May I take the liberty of awarding you my private Nobel prize  ;D
But there is already the next question, do you have any idea whether it is possible to miniaturize an electret down to some nanometers by retaining a voltage of about 0,5V?  :'(
Andreas
