LENR Roundup
Started by fritz, February 13, 2012, 03:22:12 PM
franco malgarini
profitis
....}}}}}}CX))))))»»»»»»»@
Heat/  hysteresis/ lenr/nr
wave  wave       wave     WAVE
Energy diagramaticos:
profitis
"Here is another example. When lithium is
bombarded by a proton, two alpha particles are
produced.
(2)
The sum of the final masses is smaller than the sum
of the initial values, as shown by the following data:
1.00783 u 4.00260 u
7.01600 u 4.00260 u
8.02383 u 8.00520 u
Four electron masses are included on each side. The
decrease in mass is 0.01863 u. The equivalent energy,
(0.01863 u)(931.5 MeV·u-1) = 17.4 MeV, is liberated
and appears as kinetic energy of the two separating
alpha particles.
For positively charged particles such as the proton
and the alpha particle to penetrate nuclei of other
atoms, they must have enough initial kinetic energy
to overcome the potential-energy barrier caused by
the repulsive electrostatic forces. For example, in the
reaction of Eq. 2, if the lithium nucleus has a radius
of the order of 2.3 x 10-15 m, the repulsive potential
energy of the proton (charge +e) and the lithium
nucleus (charge +3e) at this distance is
U = 1/4 0(e)(3e)/r = 3(9.0 x 1 09 N·m2·C-2)(1.6 x 10-19
C)2/2.3 x 10-15 m
= 3.01 x 10-13 J = 1.88 x 106 eV = 1.88 MeV
Even though energy is liberated in this reaction, the
proton must have a minimum or threshold energy
of about 1.9 MeV for the reaction to occur."
Thesholds will alter under hysteresis
profitis
"Axil hypothesizes that magnetic monopoles are
created as part of the LENR reaction.
Defkalion claimed to detect a DC peak of 0.6-1.6T
magnetic field at 18cm from the reactor during the
heat triggering phase.
If this was due to the formation of ideal magnetic
monopoles as Axil hypothesizes the inverse square
law 1/R^2 for distance should be valid.
If the monopoles created are small point sources,
even at a fraction of the data claimed by DGT the
magnetic field close to the surface of such
monopoles should be astronomical, making them
analogous to black or white holes. I guess that it
should be enough to cause all sorts of nuclear
distruption."
franco malgarini
Einstein's researches have only produced the atomic bomb, so what do you want? You can not stop searching ....
