Some help needed to do a Bedini generator
Started by alienas, February 27, 2012, 06:48:24 AM
alienas
Hi there, i'm new to this forum ;
I'm 45,  i've got some physic skills because i've been 4 years to highshool learning physic. But it's a long time so i've forgotten a lot.
Any way i would like to build a bedini generator starting with one coil only and i've anderstood more or less the principle but i would have a lot of questions, about how to get the parts, for instance,
are you agree to help me ?
First what coil must i use, do you do it yourself, with what gauge of wire to use ?
I've got some N52 magnets, is it too strong ?
Thanks in advance
Eric
Low-Q
Doesn't matter the grade of the magnets except the required torque to run a generator with strong neo magnets - and except the thickness of your wallet N52 neos aren't cheap.
What will you run your generator with?
Vidar
alienas
Thank you for answering !
I'm not sure to anderstand the question correctly. I'm french !
I would like to realize a model with a cd rom spining on it's motor with 4 magnets , one double coil at one point only, and 12V battery, the load would be a light ... And see how many volt i generate. In the close future, i would like to get 230 V 50 Hz alternative voltage  ;)
Eric
Paul-R
This group is outstandingly good on the Bedini. Nothing comes close
in this particular field:
http://tech.groups.yahoo.com/group/Bedini_Monopole3/
mscoffman
Quote from: Paul-R on February 28, 2012, 06:44:51 AM
@all,
I was going to post this link, but Paul got there first. I agree completely with what Paul
has said and wanted to add a few additional comments. This group expects you to build
a bedini machine pretty much identical to their standard version, then encourages you
to take data until you get results similar to what they have! This is a unique approach
and an (almost) scientific way to understand it. What they refuse to do in this group
is to discuss theory(ies) of operation or extensions or upgrades to their standard
device to make it useful.
Overunity in a bedini machine is a tough nut to crack apparently, and requires significant
tuning and experimental time, so what they provide is a firm basis for doing that.
:S:MarkSCoffman
