This might blow your mind
Started by Magluvin, March 11, 2012, 09:36:00 PM
Magluvin
Hi Mary
Not many have I would say.  ;]   Im putting things together tonight, just after American Idol. ;]
I love music.
Im thinking of adding a battery. :o   lol  not   ;)
Mags
Magluvin
From MileHigh at OUR...
http://www.overunityresearch.com/index.php?topic=1391.msg22038#msg22038
As for being smug about the whole thing, Im just sticking to my guns. I know that you cant see or understand why I continue working on these kind of things, all with a similar goal. There are many things that I could be doing. But this is my thing. Just because it is not your thing, clearly, then we just happen to like and enjoy doing different things.
Why should I follow your leader M? Tell everyone here why ?  And when they know, then they will know. But were still moving forward here toward that goal.
And as for the grandstanding, Im not going to get stuck into making fakes as you suggest.
Hey readers of this thread. Does it sound like MileHigh still is trying to convince me of building fakes instead of going for the real deal? Why is that really?  8)
Hey M. Why do you care about this project particularly? What is the attraction for you, but only to talk me into building a fake? Still?  And look back at 2009 on the same project what you had to say there.  There are many threads to speak of. Why do you have an itch for this one?
Hows that for grandstanding?
Lastly, even if I couldnt get it to work, does that mean that it couldnt for sure?  I could only tell you that I gave up to tell the truth. Or I could only say that I dont think it will work. Nothing is definite. Truthfully?   The only way you could possibly convince me not to build it, is if you even just told me that you have built it and were able to explain details of the experiment and the reasons why it wont work.  Then if it made a lot of sense, literally, I might be deterred more or less. But you havnt said you built it. Nor given any detailed reasons as to why.
So you do not know really anything. Only that you prefer that I dont build it. 8)
Transparent like a bowl full of jello. Maybe one day this will be me..   8) mags 8)
Dems my mibs
Mags
Magluvin
 8) MileHigh again, and speaking you know what, my well informed readers.  8) ;)
http://www.overunityresearch.com/index.php?topic=1391.msg22039#msg22039
Mags
romerouk
Quote from: Magluvin on March 14, 2012, 11:11:21 PM
Im putting together a base for the coil I have to mount to. And my rotor and base had some liquid spilled on it. I thought it was my cats doing at first, but I dont know what it was. Was in the closet for quite a while. So im cleaning out the bearings also. The bearings are from a hobby shop. I had taken the caps off to clean the grease out completely and ground in graphite powder a couple years ago. The graphite remains in the bearing race even when cleaned with acetone when dirty.
I tried just about every oil. Nothing worked like this....
http://www.youtube.com/watch?v=iSTfFIetYPY
And one from someone who took my advice. ;]
http://www.youtube.com/watch?v=DaG_CLsdN4M&feature=related
My 2 vids after that in my YT vid list show the rotor rundown from 1200 rpm. It took 14+ min to stop, thus 2 vids, when TY had the 10min limit per vid.
Its a bit boring. But towards the end, it seems like its just never ever going to stop. ;]
Just thought I would share that tid bit.
I soldered some longer leads to my temporary bifi before I get my supplies in. They were short for another project, but here I need change ability with connections.
Got diodes, leds, reeds, rotor on a base, reed stand, and the most important thing, NO  BATTERIES!
Hey Romero
In your opinion, does it matter if the 2 separate strands are of different size in the bifi?  If they are different, which one is which?   ;D And it would be of great help in understanding the why they should be different. If the same size, I can start winding now, not next week.  ;)   And already on 2 separate spools. That would make me happy.
Romero. Is 4000 turns necessary?   More turns, longer wire, lower freq of operation to get good effects?
And when you say the right capacitance, now I know that when the reed is released, the capacitor is not just for reed switch protection. Just figuring.  ;)
Romeros circuit is the same as Z's parallel circuit.  ;D
Thank You   ;)   Sorry for all the questions. I have more too. lol
Mags
Hi,
I believe the 4000 is required if the ball is small. A bigger ball with stronger magnetic field should work with less windings. I constructed one coil with 4000 turns and taps at every 1000 turns.
Different size wire might be required, I built my coil like that.I will try it this weekend.
Regards,
Romero
Jimboot
Ok found my unit. Couldn't get the led to light tonight so I will check wiring tmrw. It has no where Near 4000 turns though. It would be lucky to have a 100.
