Testing the TK Tar Baby
0 Members and 115 Guests are viewing this topic.
Rosemary Ainslie
Quote from: MileHigh on June 30, 2012, 11:24:08 AM
Probably the simplest rebuttal to this is that the NERD team never put a simple analog ammeter or a digital multimeter set to measure current in series with the battery connection.  That clearly shows significant current flow indicating that the batteries are discharging.  This failure to make a simple measurement as a way of double-checking your DSO measurements is symbolic of the whole mess.
We most certainly DID use a simple multimeter and were thereby able to prove that the multimeter's measurements were UTTERLY inaccurate.  It can't register at those oscillation frequencies.
Quote from: MileHigh on June 30, 2012, 11:24:08 AMWhat you are doing is an insult to the disciplines of science and engineering.  You are going to get a negative report back from the alleged lab.
LOL  I KNOW this.  It will be the same negative value that TK ALSO found.  I have NO DOUBT as to this. LOL (laugh out loud)
Quote from: MileHigh on June 30, 2012, 11:24:08 AMHopefully that will convince you and this will be all over.  But considering that you are a brick wall and stick to all of your uneducated, nonsensical, incorrect and irrational opinions about how the circuit actually works, one never knows.
Not actually.  That NEGATIVE result is PRECISELY what makes this subject of EXTREME interest to our public.  Surely you know that?  MileHigh?
Rosie Pose
Added one too many LOL's just for the hell of it and because I think MH likes to speculate on its really true meaning.  That'll keep him occupied for a bit.  Hopefully
edited.  Changed 'switching speeds' to oscillation frequencies.
And I highlighted both edits and repositioned my emoticon - and took out an unnecessary line space
picowatt
For someone who can't read their own 'scope properly, who doesn't understand how their own function generator works, and doesn't even understand how her own circuit operates, you got a lot of nerve calling others "unqualified"
What a joke.
picowatt
Quote from: picowatt on June 29, 2012, 09:08:15 AM
Dear readers,
I see from her last post "over there" that the operation of oscilloscopes, function generators, and indeed, her very own circuit, continue to remain a mystery of ill conceived misconceptions.
She continues to believe that the 'scope must be AC coupled to read the FG trace correctly.  Now she wants some method to test this.  An excellent method would be to FAX or email LeCroy a copy of FIG3 and just ask THEM what the indicated voltage is during the positive portion of the FG cycle, but then, this would be way too easy.  Clearly, she does not understand how an oscilloscope functions or how to use it properly.
In FIG 3 of the first paper, there is +12 volts being applied to the gate of Q1, which should turn Q1 fully on.  The CSR trace indicates it is not turning on.  Q1 must not be functioning or is not connected as per the provided schematic.  There can be no other explanation.  This is also evident in FIG 7, wherein sufficient gate drive is being applied to Q1 to turn Q1 on, and yet again, no current flow is indicated.
Her response at this time (she originally claimed that the offset numbers on the LeCroy were not being factored in)  is that the 'scope must be AC coupled to read the FG values correctly.  I suspect that it would take her a very long time to learn enough about 'scopes to realize and accept how ludicrous her "needs to be AC coupled" argument truly is.
From her recent post, she also demonstrates that she does not understand how to read her own schematic, how a function generator operates, or the actions that turn Q2 on in her circuit.
She claims that the FG somehow applies a positive voltage to the gate of Q2 which causes it to turn on.  Anyone that can read a schematic can instantly see that this is not possible.
In the schematic, the gate of Q2 is connected directly to the non-battery end of the CSR.  The gate of Q2 can, therefore, never be any voltage other than the voltage at the non-battery end of the CSR.  This is as plain as day for all to see.  Yet, again, she continues to believe the FG is somehow applying a positive voltage directly to the gate of Q2,  She apparently does not understand that a function generator's output swings between a positive and negative voltage RELATIVE TO its signal ground terminal.  The function generator signal ground in her schematic is connected to the non-battery end of the CSR (hereafter referred to simply as "CSR").  All can see, therefore, that the function generator output will either be a voltage that is more positive than the CSR, or a voltage that is more negative than the CSR.
When the FG output is a positive voltage in excess of Vth, this positive voltage is applied to the gate of Q1 which turns Q1 on (or at least it should as in FIG5, but mysteriously, not in FIG3 and FIG7).  Q2 remains off, as its source terminal is simultaneously made positive with respect to its gate.  There is very little voltage drop across the 50 ohm Rgen inside the FG as the only current being drawn thru the FG during this positive portion of the FG cycle is the Q1 gate current, which is very low, typically in the picoamp to nanoamp range.
When the Fg output is a negative voltage,  the negative voltage applied to the gate of Q1 turns Q1 off.  Simultaneously, a negative voltage is applied to the source of Q2 (the source of Q2 and gate of Q1 are connected and therefore always the same voltage).  When the negative voltage from the FG is applied to the source terminal of Q2, Q2 turns on (making the source terminal of Q2 negative with respect to its gate causes Q2 to turn on) .  However, as Q2 turns on, current flows thru Q2 and thru the FG.  This current flow thru the FG causes a voltage drop across the 50 ohm Rgen in the FG.  Because of this, the voltage as measured at the output of the FG, when its output is a negative voltage, can only be the Q2 turn on voltage for any given amount of current passing thru it.  Esentially, in this mode, Q2, in concert with the 50 ohm Rgen, acts as a current regulator and Q2 is therefore biased into a region of linear operation.  Ibias, that is, the DC current that flows thru Q2 and the FG when the FG output is a negative voltage, is expected to be in the 40-250 milliamp range and is determined by the FG open circuit negative voltage, the 50 ohm Rgen, and the threshold voltage of Q2 (Ibias has been measured and confirmed by both .99's simulations and TK's empirical measurements).  As one can clearly see from the 'scope captures, regardless of the open circuit negative voltage of the FG, the FG output is always at -Vth due to the voltage drop across Rgen from the bias current flowing thru Q2 and Rgen.  As the FG output is made more negative, Ibias is increased and the voltage drop across Rgen also increases.  The FG output, therefore, when outputting a negative voltage, can only be the source to gate turn on voltage required for a given Ibias.  (one would have thought that this "clamping action" that is obvious in all 'scope captures when the FG is a negative voltage, regardless of the FG offset settings, would have caused "someone" to wonder why.  And clearly it is due to the Vdrop across Rgen when Q2 bias current is flowing thru the FG)
But again, the above operation of the FG and Q2 is disputed.  She believes that the FG is somehow magically applying a positive voltage to the gate of Q2, which is very clearly just plain nonsense.  The gate of Q2 is connected to the non-battery end of the CSR, and a 'scope channel is specifically tasked with monitoring that voltage.  The FG does not cause the voltage at that point (Q2's gate/non-battery end of CSR) to go positive in excess of Vth.  Yet, the FG trace does clearly show that the source of Q2 is being made negative with respect to the Q2 gate causing Q2 to be biased on.
I suspect that no attempt was made to quantify the Q2 bias current during the March demo, as it was likely believed that all 5 MOSFET's were in parallel at that time and connected as Q1 is connected.  Had they realized that the Q2 array was inadvertently connected common gate, and understood the basic operation of that well known and well understood configuration, they may have made an attempt to quantify Ibias and provded that data in the "paper".
It apparently makes more sense, to her, to claim that the operation of Q2 is more akin to room temperature superconductivity than to accept the well understood, predicted, simulated, and empirically measured and confirmed operation of the common gate portion of her circuit (Q2).
These two issues, Q1 not turning on in FIG3 and FIG7 when it clearly should be, and her inability to understand how the FG biases on Q2 when the FG output is a negative voltage and the subsequent current flow thru Q2 and the FG, represent glaring errors and misunderstandings on her part that should be corrected in, or retracted from, her "papers".
PW
Rosemary Ainslie
Quote from: picowatt on June 30, 2012, 11:50:28 AM
MH,
Well said...
This is NOT surprising.  I can well understand how you'd recommend the use of an ammeter that can't actually read the oscillations.  It would be critical to any attempts at disproof.  We've scheduled this little test picowatt.  It's very easy to show in 10 minutes how UTTERLY erroneous is the reading on your standard ammeters which you're so desperately advising all and sundry to use.
How would you interpret/define the claim of "COP=infinity"?
HOPEFULLY you understand this now.  If not I'll gladly repost that post of mine.
Quote from: picowatt on June 30, 2012, 11:50:28 AMShe seems to have backed away from the "batteries never run down" claim, but continues to state that tests will likely show that their capacity is exceeded.
Not actually.  It's never been a part of the claim.
Quote from: picowatt on June 30, 2012, 11:50:28 AMBut if the batteries discharge at all, how can a claim of COP=infinity be made?  What if the batteries die before I am finished extracting an "infinite" amount of energy?  What would the COP be then?
We DO NOT claim that we're achieving COP INFINITY.  We claim to MEASURE COP INFINITY.  We're yet to test the effects on the battery.  Do you EVER actually check anything at all that I've said before opining about it?  Or do you just suffer from a compulsive need to bore us with your ridiculous opinions?
Rosie Pose
Rosemary Ainslie
Quote from: picowatt on June 30, 2012, 02:20:51 PM
What a joke.
So you keep saying picowatt.  But it seems that I'm way better qualified on this equipment than you are.  You seem to think that a DC coupling on channel 3 will corrupt all the other channels on our LeCroy.  That's just for starters.
Rosie Pose
