Testing the TK Tar Baby
0 Members and 157 Guests are viewing this topic.
Rosemary Ainslie
Quote from: picowatt on July 05, 2012, 11:55:40 AM
Not at all.  Sorry you missed it!
In the end, I decided your assertions were so ridiculous that they were not even worthy of a response.
If you actually believe that I some how tapped into your phone conversation, you are indeed severely deluded.
I know this to be 100% true, as I did no such thing.
Get a grip on yourself!
LOL.  I trust your gauge of 'truth' is at LEAST 100% REALLY TRUE.  Otherwise you're not giving us the 'real truth'.  Curious how truth can be qualified in terms of both percentage and a scalable 'reality'.  And I'm not sure if the 'real truth' is that I'm utterly deluded - or that you did not ENTIRELY listen in to the ENTIRE phone call.  Just some of it?
What a joke you are picowatt.  And thanks very much for making that observation.  I felt too shy to introduce it entirely on my own. I"m referring, of course, to the fact that our zipon IS that Higg's bosun - when it's OUT of it's structured field condition.   :-*
Rosie Pose
ADDED
Added
And BTW TK - our model is most CERTAINLY mathematically validated as well as being experimentally proven.
picowatt
.99,
Wow, you put a lot of time and effort into this!
Thanks for reminding me that the voltage applied to the [gate of Q1/source of Q2] is clamped at the Q2 body diode
forward voltage above the MOSFET drain voltage.  Forgetfulness comes with age!
When Q1 is fully on, the drain voltage drops to about +11 volts (with 72 V batt and 11R load).  Therefore, the positive voltage applied to the [gate of Q1/source of Q2] by the FG cannot go any higher than approximately +12.5 volts regardless of the FG open circuit voltage.  Any voltage in excess of +12.5 volts will cause the Q2 body diode to conduct.  As well, any voltage output by the FG in excess of +12.5 volts will will be dropped across Rgen and current will be drawn.  Below this voltage, only leakage current flows, which is very low.
The voltage at which the Q2 body diode turns, and at which the FG output is clamped when its output is a positive voltage, reduces in value as the battery voltage is reduced.  At Vbatt=60, the FG output will be clamped at approx +10.7V.  With Vbatt=48V, clamping will occur at +8.9V.  At lower battery voltages, clamping can occur before Q1 is fully on and thereby limit the amount of current Q1 can pass..
The IRFPG50 body diode forward voltage is specified as 1.8 volts at 6.1amps.  At lower currents, as there would be in the above instances, the forward voltage will be less than 1.8 volts (in the above, a Vforward of 1.5V was used)
Thanks again .99,
PW
picowatt
Quote from: Rosemary Ainslie on July 05, 2012, 11:05:28 PM
Rosie Pose
ADDED
Added
The bulk of this post seems nonsensical.  But you can indeed trust that my truth, as it pertains, is 100% true.
As for your" scalable reality", get a grip on it already...
As for you saying I am a joke, do you ever listen to yourself?
Bullshit.
Bullshit of the smelliest order. You have no clue at all. Go ahead, derive the permeability of the vacuum, mu-nought, using your model.
And there is no experimental "proof" either. You have neither experiments nor proof of anything except that you are daffy.
Magluvin
Rosie Pose
Is she saying she has identified Higgs bosun in her circuit?  :o
Man, all those billions on a particle accelerator, they coulda just built an Altoids.  :o :o
MaGs
