Testing the TK Tar Baby
0 Members and 147 Guests are viewing this topic.
Solstice? Equinox? You, Ainslie, continue to REPEAT over and over the same ignorant errors--- but that doesn't keep you from coming up with NEW ONES.
You know as much about the calendar and the seasons as you do about electronics and physics, apparently.... you are a month late and can't keep your terminology straight.
What a bad humorless joke you are.
@MH: You are on the right track, only the mechanism is a bit more robust. Think overlapping fixed vanes and moving vanes on an insulated axle, like an air variable capacitor.... well, not even "like" an air variable. IN FACT, it is an air variable capacitor. But the charge determines the resultant capacitance, by  moving the vanes together or apart, whereas in the normal air variable cap you vary the capacitance and that varies the charge on it.
The point, though, is that Ainslie's so-called "thesis" cannot accurately describe the ES voltmeter, NOR the device that I use to generate over 50 kV in a couple of seconds, several times during that demonstration, and many times during others. Nor can she explain how I can generate fields that exert forces many orders of magnitude stronger than gravity by running a rubber band over a plastic roller connected to a couple of soup bowls and some bead chain.
Nor can she explain the oil jet demonstration, showing charge carriers, bound to non-conductive oil, finding a weak point and fleeing the Voltage Room by the most direct means available to them as I stuff more... ELECTRONS.... into the voltage room behind them.
Capacitors in general illustrate just some of the failures of Ainslie's "thesis" even to describe many everyday phenomena accurately, much less do what she, in her magnificent delusion, claims and apparently believes that it does. And then combine capacitors with electrostatics.... and the zipons just stand around with their hands in their pockets, because there is nothing for them to do at all.... and they don't even fit the job description.
Cool TK, it feels sometimes like you have old NORAD equipment and stuff from Dr. Frankenstein's laboratory.   You should start charging admission!  lol
Quote from: Rosemary Ainslie on July 21, 2012, 04:40:44 PM
Hi Guys,
Just an update and a ramble down memory lane and renewed focus for any sincere research into this subject.
Regards,
Rosemary
http://www.energy-shiftingparadigms.com/index.php/topic,2311.msg2739.html#msg2739
Have you been drinking in the afternoon again? Misquoting, false accusations, paranoid fantasies, outright lies, threats.....  it's a typical Ainslie pile.
Quote from: MileHigh on July 21, 2012, 05:33:04 PM
Well... if things keep going the way they have been, you'll be able to pick it all up cheap at the next garage sale.
