Testing the TK Tar Baby
0 Members and 147 Guests are viewing this topic.
I think most mosfets circuits will have a similar resistor here, and the reason is probably just as you say: to make sure the mosfet starts up in a predictable state.
I swear.... it's better than watching old episodes of "Lost".
But it appears there is trouble in Paradise. A Secret Skeptic is amongst the denizens of the island, and is questioning one of the holy Creation Legends of one of the leaders.
Rosemary Ainslie
Quote from: TinselKoala on July 22, 2012, 03:53:16 PM
She tried to measure the voltage drop across the load, one time and one time only. She did it with the other scope leads connected up as normally. She also chastised me severely for "claiming" to have measured across the load, since she had such a hard time when she tried it. Of course, when I measure the voltage drop across the load, as I sometimes do.... I have the wit to disconnect the other scope probes, or to use an isolated differential voltage probe, or a scope with isolated signal references like a Fluke 199 (or 123) ScopeMeter.
I believe that this is how she damaged her borrowed LeCroy oscilloscope and had to purchase it and have it repaired and calibrated. The BNC scope probe ground connections likely welded themselves to the input jacks on the scope itself.
I think she did this by having one of the battery leads disconnected, making the scope probe ground lead connections, then hooking up the battery lead back to the battery.
This was one result:
Guys - as for the schedule of nonsense.  There's not ONE comment that's correct.  At the time that these batteries caught fire I was NOT running a test.  At the time that this fire took place I was not even in discussion with TK as TK.  He was posting under the name HUMBUGGER.  Nice to see his OPEN ADMISSION of this fact.  FINALLY.
We have taken MULTIPLE downloads of the scope DIRECTLY on the terminals from a 24 volt battery supply.  And the MYSTERY LABORATORY have also measured and confirmed across ALL 6 BATTERIES TO CONFIRM THAT THEY DO INDEED OSCILLATE IN LINE WITH THE MEASURED VOLTAGE EVIDENCE.
And sparks, with respect, one loses all respect for the platitudinous mouthings of biblical quotes - when the attempt is to enjoy the rather sparse pickings of moral superiority. The simple truth is that you are promoting and endorsing the single most disgusting effort ever made - and that made publicly - to wrest authority of comment - from the authors of a discovery that properly belongs to the world.  It does not belong to TK and does not deserve the systematic abuse of TK and his 'gang of thugs' and BULLIES
Rosemary
ADDED to emphasise the 'bleeding obvious' as referenced by Basil Fawlty'.
Rosemary Ainslie
And guys,
May I caution you YET AGAIN.  TK's manifold 'postings' of our forum work is his attempt to keep you 'misinformed' as to what we're saying.  I would earnestly advise you that IF indeed you want an 'unbiased' account of what is happening there then his references are NOT THE WHOLE STORY.  He is simply hoping to stop the traffic there.  Give up TK.  Our hit rate is already more than 800 a day.  And we're not even 6 weeks old - as a forum.
Again,
Rosemary
sparks
     Hydrogen and Oxygen are not covalently bonded.  Monatomic hydrogen doesn't covalently bond to anything.  It forms hydrogen bonds like in hydrocarbons.  These are ionic bonds.  Anybody who tells you that hydrogen is covalently bonded in a water molecule is an idiot.   The two hydrogen atoms in a water molecule do not share electrons they remain fully ionized with a net electrical charge of one.  The oxygen atom remains with a net charge of minus 2 therefore two minus 2 allows the water molecule to remain electrically neutral forming an ionic substance.  The only reason water is liquid at room temperature is due to the electrical polarization of the molecule forming rings of water.  Due to this each water molecule is a capacitor.  Two unlike charges creating an electric field between them is pretty much a capacitor. When the capacitor is caused to discharge the binding energy becomes ours to use.     When the water molecule is subjected to a dense electric field this ring is destabilized and the water boils.  Myers was not repeat not using the vic to produce hoh gas or any of that.  He was forming water vapor with very low energy input using Tesla highly efficient high voltage tech to generate intense electric fields in his "fuel cell" :P .  He was using alot of high tech shit like lazer induced  coolumb explosions. The water vapor was then subjected to ionizing radiation again in a dense elecrtric field  which created ionized monatomic hydrogen which is better known as a proton,  The proton's were then mixed with 04 which created rocket fuel better known as hydrogen peroxide.  Hydrogen peroxide is a rocket propellant and torpedo propellant.  Which then propelled the vehicle down the road.  The copious amounts of gas you see boiling off his fuel cell is water vapor.  You will notice he makes no attempt at seperating the gasses.  They just go up to the top of the cylinder and everybody assumes it's hoh gas.   I tell you something weird is going on in a highly electrostatic field where emradiation gets red shifted to very low frequency waves that begin to look like the rays coming out of protons.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
