Testing the TK Tar Baby
0 Members and 196 Guests are viewing this topic.
Quote from: picowatt on April 29, 2012, 12:15:22 AM
TK,
Are you going to use your bias source with its ground at the battery ground, as shown in .99's sim schematic which is identical to the March video?  Or are you going to connect the bias source ground to point 4 as per the schematic in the first paper?
PW
I can do either one.
However, I am TRYING to use the same points and the same circuit that Ainslie claims to produce her effect. We have asked several times for her to be SPECIFIC and CATEGORICAL and let us know the TRUE schematic. Since the one-mosfet circuit, the demo diagram shown in the demo, the actual demo circuit, the diagram in the first paper, and the diagram in the second paper are ALL DIFFERENT and none of them have been CORRECTED BY THE CLAIMANT (sorry, I have to shout to reach the peanut gallery evidently) it's still in question which one I should waste my time on.
I am using the diagram below, and my board incorporates the 555 timer circuit and the 555 inverting charge pump circuit, both of which can be disconnected by jumpers and either or both of which can be connected by jumpers in place of the FG or bias battery.
(I've also provisionally dumped the power resistors and installed a 0.2 ohm single actual CVR in place. If I can still get the negative power product I'll leave this one in place. If not I'll change back to the cement resistors.)
(There is also a 0.3 ohm CVR in series with the 10R at the "FG+" input point on the board. This can be used to view the current coming to or going from the FG or other bias source. According to Rosemary, this voltage drop should always be zero across this resistor, since no current flows through or from the FG in her circuit.)
picowatt
TK,
I watched the Mylow vid.  Rather than have the large disc permanent magnet motor driving the little motor with fishing line and then taking the output from the little motor and using its generated voltage to backdrive the wall wart to power your house, have you considered putting coils on the PM motor to generate directly?  Might be more efficient.
PW
Quote from: picowatt on April 29, 2012, 12:26:38 AM
TK,
PW
Made my day. Now I can sleep easy, thank you....
;D
picowatt
Quote from: TinselKoala on April 29, 2012, 12:26:05 AM
TK,
So that would be identical to .99's sim schematic with the FG/bias source ground moved to point 4, which would make that sim schematic similar to the first paper schematic.  That way Ibias is accounted for by the CSR trace.
I knew you knew that.
PW
picowatt
TK,
Was the Tek manual link a good one for you?
PW
