quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
0 Members and 36 Guests are viewing this topic.
markdansie
Still dreaming I see, good luck I hope it works
Mark
profitis
@markdansie..we dont believe in dreams.we dont believe in luck.we believe in something that can power an ipod or radio at a less expense,less effort than a plug-wall charger,or a chinese zinc-carbon. It works.
sarkeizen
Quote from: Enormous Obstructionist Asshole on November 18, 2013, 02:56:18 PM
errm @sarkeizen..formal argument?fail?
Yep.  You have failed to make your point.
QuoteA karpen cell will absolutely not stop until you maintain a   pressure difference between the two gaseous electrodes.this you can test .this you can check.this you can 1)see,2)feel 3)touch 4)test
"Running forever" can not be felt, seen, touched or tested (empirically).
5)mathematicize.this
If so, you have not provided a formal argument to this point.  So you have failed to make your point.  There is no cite which explicitly states your point, nor is there a formal argument presented which goes from what was stated in a cite to force your conclusion.
How is this anything but you failing?
@ sarkeizen is revolutionary..we are entering a new age with new energy sources.money is to be made.
Nope.
profitis
 running long enough can be tested @sarkeizen.long enough to divorce from the wall-plug.my point is you cannot divorce any electrode potential from its work function:E=wf + contact potential with electrolyte(wikipedia).thus to prove wikipedia is correct we can take e.g. two copper electrodes,one rough,one smooth and shove them into copper sulfate solution under argon or nitrogen and get a measurable voltage and current.same with gaseous electrodes.
sarkeizen
Quote from: Enormous Obstructionist Asshole on November 20, 2013, 12:28:12 PM
Sure, if you run something forever it can be said to run forever.  Anything less is not exactly demonstrating forever as forever is infinitely larger than any finite period.
No cite, no formal logical argument.  Still a fail.
