quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
0 Members and 28 Guests are viewing this topic.
profitis
if you scroller down here www.chem.queensu.ca/people/faculty/mombourquette/Chem221/8_Equilibrium/Electrochem.asp to the section titled 'electrode concentration cells' you will see the category for our cell @sarkeizen.hydrogen gas is the species.i.e. platinum will soak up a vastly different amount of hydrogen gas than gold will.enough to create a voltage up to 1volt in fact.
sarkeizen
Quote from: profitis on December 23, 2013, 10:45:50 AM
so let me explain how a hydrogen concentration cell runs flat @sarkeizen.it decompresses gas at one electrode and squashes it on the other.after that,its flat.dead flat.incapable of further work ok? Notice it does this when switched on ok(duh..logical).notice it doesnt do jackshit prior to being switched on(duh..logical).in other words its most stable state when switched off is the gaseous concentrations prior to being switched on.and its most stable state when switched on is a gas pressure differential ok?ok @sarkeizen?with me so far?
Cite please.  Please consult the format I gave you and the many times I explained to you the rationale for it as well as the many times I explained how what you did - is not providing a useful citation.  All of which I did using small words no less. :D :D :D
profitis
@sarkeizen 1) all ambient pressure gaseous electrode concentration cells must have a gas pressure difference in them after switched on.  2)all ambient pressure gaseous electrode concentration cells must have zero gas pressure difference in them when switched off therefore 3)all ambient pressure gaseous electrode concentration cells must be able to run flat,incapable of doing any more work,over and over again ad infinitum in a repeatable cycle due to gas pressure differentials during on/off phases.you dont need any more cites.
sarkeizen
Quote from: profitis on December 24, 2013, 01:24:58 AM
Please provide the requested cite.  As per the definition repeated many times, with examples given many times and the rationale given many times.  You haven't provided a cite.
You did promise "all the cites and logic I could ever dream of" but "promise" to you means "lie" right?
profitis
 maybe you do need more clarity.check out the example under sub-title 'electrode concentration cells' here www.emedicalprep.com/study-material/chemistry/electro-chemistry/concentration-cells.html .this is an example of a non-ambient pressure hydrogen electrode concentration cell.they use identical work-function electrodes and begin with a pressure differential,and end with equal pressure.we use different work-function electrodes,begin with equal pressure and end with differential pressure @sarkeizen.
