quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
0 Members and 31 Guests are viewing this topic.
lumen
Quote from: MileHigh on November 04, 2012, 08:08:28 AM
Lumen:
Your comments are nonsensical.  You are implicitly conceding that the toaster oven is not an isothermal environment but you have a Lumen-inspired "work around" for the problem.  Just rotate the tubes like barbecue chicken and if they produce current in a variable-temperature environment then all must be fine.
Your "problem solving" is severely limited.
Umm, works for chicken!
The idea is that if uneven heating is a problem, it will show up as changing polarity or changing current, provided the tube is rotated slowly. If the tube is rotated rapidly then there could be no such thing as uneven heating even if you used a cheap heat gun!
So think about that limited problem solving.
It doesn't really make any difference now since it appears Philip has his Quenco chips working!
"We now know how to produce almost perfect Quenco's,
and we will make a 2cm x 2cm array of 4mm2 Quenco's,
mounted on a 115.5 x 62.1 x 12.3 mm heat absorber.
We will use this array to perpetually power an iPhone,
an extraordinary claim requiring extraordinary proof,
a witnessed working device."
OFFICIAL LAUNCH
30 November 2012
6pm (p.s.t)
Bruce_TPU
Lumen:
I am about sick of a couple of you on this forum.  Why don't you go back with your buddy TK and use your "problem solving skills" to design a "working" whipmag.  Oh, wait, you did that, but it was a fraud.
At least lumens is testing something.  Instead of fault finding anyone really interested in finding some real solutions.  You have an agenda and TK has an agenda.  We on this forum are wise to the both of you.
Have a nice day!
Bruce
Lumen:
There is an expression about counting chickens.  You say the incubation period will be over at the end of the month?  We will both have to wait and see.
Bruce:
You can't fit a square peg into a round hole no matter how much you try.  Lumen is not testing anything, we are discussing Elisha's testing.
Now, Elisha's test is either an isothermal test or it's not an isothermal test.  The TRUTH is that it is CLEARLY NOT an isothermal oven.  Now, is this progress, to do improper tests and then just push ahead and act like you are deaf, dumb, and blind?
What is your opinion, do you think Elisha's test setup is an isothermal setup, yes or no?
Here is the problem Bruce:  If you close your eyes and say, "Yes, the toaster oven is an isothermal setup" then were does that lead to?   What are the possible consequences?
Well, a few people have been killed transferring liquified "HHO"  (really 2H2 + O2) from one container to another.  The roof blew off of a building in California last year, it was in the news.  Handling "HHO" is like handling a bomb - nitroglycerin - one tiny static spark and boom you are dead.
Or, your thinking based on wishful thinking and blinding yourself to the truth leads to things like Thalidomide babies.
QuoteThalidomide, launched by GrĂ¼nenthal on 1 October 1957,[10] was found to act as an effective tranquilizer and painkiller, and was proclaimed a "wonder drug" for insomnia, coughs, colds, and headaches.
In the late 1950s and early 1960s, more than 10,000 children in 46 countries were born with deformities, such as phocomelia, as a consequence of thalidomide use.[11] It is not known exactly how many worldwide victims of the drug there have been, although estimates range from 10,000 to 20,000.
So sorry Bruce, a toaster oven is NOT an isothermal oven, and you should face up to that fact.
PS:  I had absolutely nothing to do with the Whipmag.
lumen
Bruce,
Sorry Bruce, I'm not the one doing the testing. I'm just lining up the life failure skeptics for the soon to come crow feast.
If any of them would have done any research, they would have known that the principal (electron tunneling due to heat) has been a problem in the MOSFET industry when they tried to reduce gate barriers to less than 100nm.
Can you imagine the tunneling you would get with a barrier less than 1.5nm!
But you know how they are.  ::)
I don't want to say too much, I'm already -10 points with Philip.
PeterMax
Update on the website (quentron.com) regarding the launch:
For the launch we will have 3mm diameter Quenco's
These devices will be available as loans to licencees
We will also make an array of 3mm diameter Quenco's
The array will be mounted on 1/8th thick Aluminum plate
The desired output will be 5.1V @ 3Amps via a USB
Sufficient to perpetually power an iPad with no battery
I would like to nickname this integration as the QiPad
I hope to be able to get Eric Wesoff to test the QiPad
Eric seems to me to be 100% sceptical about Quenco
There can be no better report than one from a sceptic
(Eric Wesoff is the Editor in Chief at Greentech Media)
www.cleantechlawpartners.com/CLP/Eric_Wesoff.html
OFFICIAL LAUNCH USA & EUROPE
30th November 2012
