quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
0 Members and 31 Guests are viewing this topic.
trim12
The main site now says there will be a weeks delay in the launch.
not_a_mib
The launch will probably get delayed until December 21 so that it can fulfill the ancient Mayan prophecy of great change on that day.
Patience is a virtue worth waiting for!
P.S.  Is it really true that the Yanks talk funny and drive on the wrong side of the road?  Being one myself, I could never tell if this is really true.
Bruce_TPU
I am surprised that there has not been more discussion of the possible physics at work in the device.  It would appear to of course use electron tunneling.  BUT the very interesting thing that Phillips seems to have understood and put into place, is that the thinner the material, the greater the probablilty of tunneling.  Very interesting  indeed.  This would explain why the thinner the material, the greater the output.  And then they are stacked of course.  The entire subject of electron tunneling is facinating indeed!
Press on, Phillip!
Cheers,
Bruce
Elisha
Hi all
We are moving ahead, and Philip has the required materials and is manufacturing the first Quencos.
As we said before, a delay in the launch is more than acceptable, Philip is making a huge effort bringing this important development to reality in record time.
This is my update for the Ten licences: 1- Intel corporation, 2- Samsung electronics, 3- TSMC, 4- Global Foundries, 5- STMicroelectronics, 6- UMC, 7- Texas Instruments, 8- LG electronics, 9- Qualcomm, 10- Nvidia.    In the line up are Hynix, Micron, Infineon, Freescale, Toshiba semiconductor.  Also can include Google, Apple.  Anyone of this companies will pay billions for a licence.
All the best !!
Qwert
