quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
0 Members and 86 Guests are viewing this topic.
lumen
Quote from: sarkeizen on January 23, 2013, 06:28:16 PM
Are you saying that it couldn't be done on a CPU lacking a privileged mode? (e.g. Rings 0,1,2 on the x86)
I'm saying it could be done on a CPU with privileged mode.
On other CPUs it would be dependent on their specific resources, interrupts, timers, range of calls and jumps and other available external hardware.
sarkeizen
Quote from: lumen on January 23, 2013, 07:03:23 PM
Please provide a set of minimal constraints for a CPU which would make it certain that the halting problem can not be solved on it.
I realize that you, not having very much background in math might find the above statement difficult to understand.
Think of it like this:
Describe a processor or reference a real one and a case where it is unable to solve the halting problem.  You will be able to tell if the case is minimal if the halting problem can be solved by adding a privileged execution mode.
i.e. a 6502 which only has access to human input and memory can never solve the halting problem.  However if it had a privileged running mode (e.g. Ring0) it could solve the halting problem.
sarkeizen
Well that was fun...I wonder if lumen has conceded the point yet?  I wonder if he realizes he's trapped yet? or that his stated algorithm for detecting infinite loops doesn't meet our requirements?  Which is another way of saying that is to say it doesn't work!  I hope I'm not 15 like lumen said, otherwise that would be pretty humiliating for a 30 year old engineer/programmer to be schooled by a 15 year old.
If anyone else doesn't understand where lumen is wrong, or wants to pick up the argument where lumen left off then feel free to post.
Bruce_TPU
Quote from: sarkeizen on January 24, 2013, 08:55:36 AM
sarkeizen
...and while the rest of us are talking math and science Bruce_TPU comes in to whine...perhaps because he hasn't been able to participate.  Don't worry Bruce_TPU I'm sure there's some thread going on that involves construction paper and crayons...perhaps building a OU heat engine from it!
It's interesting that according to Bruce_TPU being right about something that is, for a computer science student about as fundamental as 1 + 1 = 2.  Is conceited. Also it seems he can't tell the difference between a formally proved theorem and asserting one is right because one can't doubt himself - sort of like lumen does.
I confess I'm a little eager to crush lumen's argument (and is astronomical arrogance along with).  He was going down the garden path so very nicely but as I've said, perhaps he realizes that he's done in and sodded off to nurse his ego.
