quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
doublehelix
I think the length of posts on the subject of a computer program on this quentron thread set an overunity record for trolling.
It is disrespectful to the members of Overunity and I ask Sarkeizen to please desist from making any more posts off topic.
sarkeizen
Quote from: doublehelix on January 31, 2013, 02:10:13 AM
Trolling is what Bruce_TPU does - posts deliberately provocative messages which are otherwise vacuous and you're right he should stop.
I came up with a logical argument as to why Philip's idea can not work.   Drawing on information theory and complexity theory.   Lumen believed that I don't understand Philip's design which I agreed with because Phillip has produced nothing in terms of a design that shows how 2LOT is violated.  Lumen then went on to argue that if I don't understand some arbitrary level of detail I can't say that something doesn't work.  The foray into an exceptionally well-known road in computer science to disprove Lumen's point is at best a digression.
If Lumen had conceded the point - upon which there is no disagreement among mathematicians (mathematical proofs are often like that) - it would have been a short argument and we could have gone back to talking directly about Quenco.  Instead he wheedled and whined and tried to find some silly excuse for not losing and then he left in a huff.
We still can get back to the problem with Philips idea - if you want to concede those points I mentioned.
Groundloop
http://www.theimagingsource.biz/en/technology/ambientheatelectricity/
QUOTE:
The Imaging Source Technologies
Ambient Heat To Electricity Conversion
The Imaging Source Europe GmbH presents a new technology to convert ambient heat into electricity, while at the same time cooling down the surrounding area.
No other external energy is required besides ambient heat.
This new technology resolves several long known problems and opens opportunities for chip cooling without heat sinks, powering portable devices without batteries, designing tunable radiation sources in LIR and building new energy harvesting and cooling devices.
This technology proves that cooling does not require the input of external energy.
END QUOTE:
GL.
Groundloop:
There are a lot of problems with that link you gave us.  There is a delicate art to reading between the lines when you look at a company's web site to determine if they are real or not.  I see many warning signs.
Bruce_TPU
I could not agree more doublehelix!  Enough is enough.
@ Stephan -
Please BAN Sarkey from this thread.  You need only read his posts to know why.  Too many reasons to list here.
We members would be THRILLED!
Kind regards,
Bruce
