electrolysys with horizontal plates
Started by Walter Hofmann, July 02, 2006, 03:56:31 PM
Walter Hofmann
Hi all,
here just a bit info about my weekend experiements.
Attached are a vid about testing for pressure the vid shows with 2 seperate cells each with a three stack of disc horizontal. both cells in series on 12V. the time to build up 5psi is 6 minutes.
I will post a nother vid what shows the next step.
greetings
walt
Walter Hofmann
hi all,
here a the next step, the vid shows a one cell setup where the cell has a stack of 5 horizontal disc it is on 12V and the time to generate a pressure of 5 psi is only 1 min. now.
I also did a test with my 3hp engine and here are the results:
the setup was the 2 cells .
I could not start with the gass alone, also I did two testruns with gasoline to find out how long the engine whould run with gasoline to see if the gas has any effect at all. the engine with about 0.2cc run for 3 minutes. then I put the electrolizer hose direct in to the carburator closed the air intake ( filter) with only a hole of about 1/2 inch and the engine did run for 5min and 10 sec. the engine did run on a higher rpm in the moment as I turn on the elect gass. But overall the 2 cells did not generate enough gass.
The next step will be now to build two of the 5 stack cells and test again.
I'll keep you posted
greetings
walt
hartiberlin
Hi Walter,
great videos and tests. Many thanks.
Please be sure not to generate too high pressures oxyhydrogen, cause it is very explosive,
if the pressure is too high and it could selfexplode !
ALso be sure NEVER to photograph the gas with a Fotoflash camera, so never
use flash to photograph it.
The flash energy can be enough to fire the explosion up of it over a distance !
Good luck on your next motor tests !
Regards, Stefan.
joule
Walter!
video is nice, although I have a question from what I saw. From the looks of the gas in your bubbler, I doubt that you are getting much over a few liters. What is the current at the 12V input?
Here is a very rough way to tell approx gas (give or take). If you have a clear cell that you can use a marker pen on, fill the cell with 50ml to 100ml at a time and mark the last few additions on the cell face. You can use a rough interplulation to gauge water consumed. 18mL for a mole or approx 22.4L.
You will get approx 2.7 watts per STP liter.
Maybe this will help.
Walter Hofmann
Hi joule,
the current pullet from the 5 stage cell is 22 Amp at 12V. I got no idea how to realy measure the amount of gass. I just know with the bottle version what is also just somethings rough to give any idea if with the different setups is a increase of output, it takes about 30 sec for a 1/2 liter bottleto be filled.
For me only count what I can power in real life, for instance a IC engine of 3 or more hp to be usefull for my generators.
Back in the old days we had a saying that "all theorie is gray" I believe in results and dont care what the theorie says if we look back just a few years there was claimed pretty much from all major sience that it is not possible to poaer a IC engine with hydrogen, right? and what is now. If they find a good way to charge for it it is done.
Next weekend I will try again with the 5 stack cells to power the little 3hp engine lets see how it turns out. Hey I be allready happy that I could extend the running time of the 3 hp engine not quite double last weekend with the 3 stage cells. every little bit saved helps the budged.
In regards to the amount of water used to power something I believe it can not realy be measured by the amount of water lost in the cells because many have reported including credible institutes that a amount of 4 ounzes was enough to get 50 to 100miles with a car and there are many facts which playa role ther too like temperature etc.
lets see how it works out.
greetings
walt
