electrolysys with horizontal plates
Started by Walter Hofmann, July 02, 2006, 03:56:31 PM
hartiberlin
Here is the 3rd video from Walter , where he did let some air into the bubbler to mix into the
hydroxy gas, so the motor almost starts to run, but still too low volume
of gas.
Okay, this is now at about 360 Watts of input power.
Walter will now double the the electrolyzer cells to 4 cells
and will see, if he gets it to run then finally.
Well done Walter,
regards, Stefan.
joule
360 Watts?
Watt/seconds or joules or watt/hours.
If I calculate it correctly with 2.7 watts per STP liter or ~ 60.48 watts per mole, then to get 360/2.7 = 133.33 liters? It does not seem that the gas production in even near this level? Wish him all the luck in the world, but I did post some time back that to run that engine on single duct gas only he would need about 4000 Liters per hour. 4000/60 = 66.67 liters per minute? Don't think so.
hartiberlin
Okay, Walter emailed me again the results of his new tests with
2 x 2 cells so 2 in series and 2 of the units in parallel at 12 Volts and
drawing 55 Amperes.
Here are 2 pictures and the 3 videos he did send in the next posting.
hartiberlin
Here are the 3 Videos Walter did send me.
Now with 660 Watts of input power the motor is running already a few seconds,
but it would need probably another 2 cells for the motor to run completely
on hydroxy gas.
So with about 1000 Watts of input power this thing should finally
produce enough gas to run this lawnmover motor.
Ans this is still with just 12 Volts DC and no pulsing yet.
Many thanks to Walter for working so hard on it.
Regards, Stefan.
P.S: You have to be logged into the forum to see the pics and download
the videos.
hartiberlin
The main problem Walter still  has in this moment is still,
that when the motor sucks in the gas from the bubbler
and creates a vaccuum in his bubbler the
cells stop producing the gas, although the input power is running  !
How can this be ?
Does the water inside the bubbler maybe then have more surface tension
when there is a vaccuum ontop of it, so the
hydroxy bubbles can?t go through
and need more pressure to go through the water ?
Or how can this be ?
Maybe somebody can answer this ?
Many thanks.
Regards, Stefan.
P.S: Has anybody seen any video from Tero Renta
and his experiments with his engine ?
Where is it ?
