Accelerating wheel modeled under real world conditions - could it be?
Started by AquariuZ, April 11, 2012, 08:45:05 PM
4Tesla
Quote from: AquariuZ on April 13, 2012, 08:56:40 AM
Here a few pictures what I am thinking of.
The wheel with bolts will almost look like a Western Saloon Gambling Wheel.
Thanks for this post.. I understand how it is suppose to work now.  8)
oscar
Hi AquariuZ,
While thinking about your idea, I feel that there are two basic options:
option a)
iron pendulum weights are used. A magnet is used (as horizontal force Fx) to displace/attract them.
option b)
magnets are used as pendulum weights. Then iron OR a magnet can be used to create Fx.
I think option (b) opens an additional possibility to create horizontal displacement:
using another fixed magnet ON THE LEFT SIDE of the wheel.  This magnet could PUSH/REPEL the pendulums to the right. That would increase the turning force.
Do you agree?
PS: I am attaching an image of AquariuZ's original model, showing his basic idea.
The transmission was a '53 (Johnny Cash)
AquariuZ
@oscar,
yes, good observation.
But there will be drag in either option which is basically the same as friction  :(
Even though I think there will still be an effect, the pull and the drag might cancel each other out-
But to be sure correct positioning of the magnet needs to be tried out.
I also was thinking about the pendulums being able to move only in a counter-clockwise direction using a spanner mechanism in the joint. Not sure how to describe it, but what I mean is something with teeth that does not allow the pendulum to swing left, only right.
That coupled with minimal Fx should be enough.
Look at this interesting video of a Mikhail Dimitriyev design:
http://www.youtube.com/watch?v=ODf49HtCNj0
only ¨pendulum" movement in CCW direction while the entire assembly moves CW.
and only two or max 4 weights needed.
If only I knew how to model this... Trying.
Thanks oscar
oscar
Hi AquariuZ,
Thanks for posting a link to the Mikhail Dimitriyev simulation.
Quote from: AquariuZ on April 15, 2012, 12:30:07 PM
Ok:
your original idea will work, but only if the wheel can turn with very low friction. One can model/set the friction of the wheel's central bearing in wm2d, and as soon as one does that, it does not work any more.
Preventing the pendulums from swinging back after they were attracted towards the magnet, is a good idea. Because as long as they can swing back freely (= loose their displacement) they exert the necessary force to drive the wheel only very briefly.
If they would stay displaced, they would exert that force for a longer period and the wheel would become more powerful.
The mechanism you describe is a ratchet, also called a freewheel clutch.
http://www.ringspann.com/en/Products/Freewheels/Overview__403/
Yes, to have that is a good idea, in my opinion.
AquariuZ
Quote from: oscar on April 16, 2012, 02:56:49 AM
Exactly what I meant... thanks oscar.
