Radiant Electriciy Generated with Spark Gaps and Induction Coils - Theory
Started by bajac, May 07, 2012, 07:14:01 PM
nix85
Quote from: Floor on September 25, 2021, 03:01:19 PM
@nix85
I read works by H.P. Blavatskiy,  C.W. Leadbeater, and Annie Besant when
I was in my late teenage years and early twenties.
Some of which I keep to this day. Out of the many theosophisit's works,
Light on the path, as written down by Mabel Collins is the work I most
value and respect.
Be that as it may, I find in the lectures of J krishnamurti something truly transcendent
of the whole of theosophy.
regards
     floor
That's good, those are valuable sources. I have books by all of the noted.
Yea Krishnamurti was the real deal. I prefer his lecture for the group of young people where they were indifferent, then when someone brought up 'Atman' he said like 'Who's that guy, where is he" and they started mumbling, and then he went like "See now that i touch your beliefs how you got jittery". I read he was picked by Babaji along with few other youths of his time to spread the word.
Beware that he later disowned Theosophy as a movement cause it got inflitrated.
Floor
@onepower
The layout of time I gave, is a kind of physics explanation of time.
Time in a physics context, as I understand it.
The idea of subjective and objective or that the describing of anything
must be, from a point of view, is way older than modern scientific method.
Science has had to come to some kind of terms with this since its beginning.
A clock wise spinning motor shaft rotates clock wise only when viewed
from one end of the motor. It spins counter clock wise when viewed from the
other end.
Imagine two men getting into a fist fight,   ;)  because each one knew with total certainty,
the direction of the spin of the motor they were installing. Clock wise, no it's counter
clockwise, no clock wise... .. .
If those two men were instead observing the rotation of our galaxy, one from "above"
and the other from "below"  :)  would you say that the galaxy was reversing direction
depending upon the perspective ? I wouldn't.  Then again, any of the more egocentric
parts of our selves, probably would. But in terms of meaningfully defining or measuring
many of the galaxy's physical aspects, one would need to first define a frame of reference.
Inertial frames of reference, and relativity and even Einstein's special relativity are the only
way physics has found to describe certain phenomena.
Is the perspective of one's having a perspective the ultimate perspective ?
Not from my point of view.
One could simply turn away from the galaxy and look in another direction.  Time is
a bit more pervasive. It's more difficult to step outside of time.
https://www.youtube.com/watch?v=VVro5wxqh4U
nix85
I might add that in one contact case (and there are others similar to this) they said their time is out of phase with ours. We know 7 great spirals of astral matter surround the earth millions of miles into space, these are full of life of which this so called physical plane is a copy, NOT vice versa. Cities, industries, people, every single thing that is here is first there and much more that has not yet been clothed in the substance of this plane.
There are also 7 negative levels within the earth also spanning millions of miles, how is it possible, it is cause it exists on higher frequency, more waves in same space.
Interestingly, time on the lower astral levels above earth where most go when they 'die' (no such thing as death) is in sync with our time.
More about this movie Astral City based on material given through world known medium Chico Xavier.
And the book of same name http://www.oconsolador.com.br/linkfixo/bibliotecavirtual/ingles/AstralCity.pdf
What you see below are mountains of astral matter of which there are thousands all over the planet over all mayor cities. Inside these mountains is 'umbral' aka shadow zone, obviously word is similar to umbrella. These are the limbos, purification zones. On the top are cities of light, you can see the shaft of light projecting into space.
onepower
Floor
You didn't answer the question and as I said nobody probably will.
Here's an easier question... why would you think the material properties of an object, our clock, wouldn't change at very high velocity?.
It seems pretty common sense considering space is not empty but full of plasma, high energy particles, radiation and em waves. Obviously something moving faster would interact with more stuff more often. Yet somehow everyone  got it in there head that time somehow miraculously changed. It's the most bizarre thing I have ever seen and cannot understand  how anyone could come to that conclusion.
I mean it wasn't that long ago that claiming time was variable would be met with hysterical laughter. Like little Joe thinking he could fly by tugging on his boot straps, lol. Yet somehow most bought into this strange belief.
Meanwhile nix85 is trying to argue he's immortal, lol. Things are getting really weird out there and I'm not sure anyone should be giving people advanced technology. Many are even throwing around the nuclear option because they actually believe they cannot die... fruit loops and unicorns.
AC
