The conversion of electrical energy to heat energy.
Started by vironika, May 18, 2012, 02:14:03 AM
vironika
Question: Using a Joule's calorimeter to investigate the efficiency of the conversion of electrical energy to heat energy.
Equipment:
Joule's calorimeter
balance
thermometer (0-100degrees celsius)
power supply (0-12V)
ammeter (0-5A)
rheostat
stopwatch
electrical leads and distilled water
We carried out the prac to find the efficiency of the calorimeter with a copper coil, But we had a slight hick-up, we kept getting over 100% efficiency instead of under 100%. This isnt possible because we're not turning heat energy into electrical energy. Here are our results after we did the prac:
Initial temperature = 23degrees
Final temperature = 44.5degrees
Temperature equilibrium = 21.5degrees
Mass of distilled water = 0.094kgs
Mass of calorimeter = 0.122kgs
Current (I) = 2.2A
Potential difference (V) = 3.8V
Time = 880seconds
Specific heat capacity of water = 4180
Specific heat capacity of copper = 390
Relevant equations
P = IVt
Q=mc (delta) t
My attempts at the solution
P = 3.8*2.2*880
P = 7356.8W or 7356.8Js
Q(copper+water) = (0.0943*4180*21.5) + (0.122*390*21.5)
Q(copper+water) = 9497.7
Efficiency:
9497.7/7356.8 x 100% = 129.1% efficiency. How is this so? shouldn't it be lower.
Does anyone know what could be the problem/s. How to fix this issue? we tried 5 times and cept getting over 100% efficiency, Is there anything we can change to correct the efficiency?
Thank you
_______________
websites for sale
alopecia cure
DaS Energy
Hello Vironika,
The stats you pulling may be true.
For Heating Flowing Water  KW = Liters/min. x Temperature Rise (°C) x 0.076
Peter
TechStuf
The effects of sonoluminescence due to cavitation in electricity driven rotary systems such as Joe Grigg's Hydrosonic pump also produce heat energy at over 100% efficiency.
http://www.youtube.com/watch?v=yh_-DUKQ4Uw
EM induction systems can be quite efficient at converting flux "eddies" into heat.
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
