Continuously Flowing Water Theory
Started by johnny874, June 09, 2012, 10:02:52 AM
excessAlex
Idea
yes..i know, the tube at the bottom should be placed as high of the lower reservoir..  ::)
johnny874
Quote from: excessAlex on June 29, 2012, 06:42:31 AM
Idea
    excessAlex,
I was going to say I like it. One thing you would need to add is a reservoir under the water bucket. When the water bucket empties into it, it would float the water bucket back up reseting the pump. I think this part of the design will always need
to be a 2 stage set up. This would let one reservoir  reset the pump while the other (lower) reservoir primes (fills) the pump.
        Jim
excessAlex
actually the animation above lacks some check valves and shutoff valves. The mechanism that I have shown schematically does not move in a native, but must be adjusted by opening and closing the valves so as to allow time for the containers to exchange the liquid, and passing air to the piston when it is in the rising phase and in the filling phase.
Bearing in mind that the two intermediate containers - when empty - have the same weight, and the lever that moves them is 1:1 my only question is: Can the weight of the water in the upper-intermediate vessel to overcome the force of gravity and friction of the pipes to allow liquid to back up the container at the top? .. I thought of working with containers from 30 liters up, maybe 100 liters ..
I hope you understand everything that I wrote, english is not my natural language
( P.S. That animation has its flaws, because I'm not quite able to make animations, some solutions that I have represented are done so because I could not do better with the drawing software .. Actually you can improve it a lot )
johnny874
Quote from: excessAlex on June 29, 2012, 11:54:55 AM
  excessAlex,
I wish I had watched the wmv. earlier. About the only thing that would need to be changed is the way the hydraulic piston works. I attached a drawing that shows how you can use leverage to increase the force for pumping and allow for easier resetting/priming of the pump.
Also, your English is quite good. What is your native language if you don't mind my asking ?
        Jim
edited to add; I think I like the way you thought of better than what I came up with  :D
by the way, something working with a liter or 2 would be enough to impress most anyone  ;)
Ghost
I think using leverage is probably the best way to pump water up.
I don’t see this in excessAlex’s design.
I could be wrong though.
