Working SMOT ramp from Tom Ferko ?
Started by hartiberlin, July 12, 2006, 10:42:03 AM
magnetman12003
Hi,
Here is an explanation of the above illustration.
Tom
Low-Q
Quote from: hartiberlin on July 12, 2006, 10:42:03 AM
Hi,
here is a real new great magnet Video setup for a working SMOT ramp
with a big rollaway from Tom Ferko:
http://video.google.com/videoplay?docid=-6531588179303444480
The question is if this device is in level. What happens if the device is placed in the opposite direction?
It will then probably not work.
Br.
Vidar
magnetman12003
Hi Vidar,
I only did this  --my first ---experiment on a level surface and it worked in a linear way.
So far I have not found a way to keep heavy ring magnets rolling continuously in a circular fashion.  I am wide open for fresh ideas.
I keep trying however as these magnets have a lot of magnetic energy which I believe when finally tapped in mechanical way will result in an all self powered motor.
Its all in wishfull thinking right now but I figure soon someone will find a way -- maybe using a little help from gravity.
Tom,
magnetman12003
Hi All,
I am starting to build this.
Tom
Low-Q
You have a force between the magnets and gravity. The sum is a force 90 degrees on the circles tangent - in which does not provide any rotation. Even the steel ball is pulling the rolling magnet back a bit. And the force between them will also be 90 degrees on the circles tangent between them. Again the sum is 0 force to make it rotate. you have to provide a force that is more or less than 90 degrees on the tangent where the magnet is touching, but this is, as far as I can see, not possible without external energy.
Br.
Vidar
