Using Chas Cambel Flywheel System For 15 Horsepower
Started by thankGod, June 25, 2012, 11:57:43 PM
ARMCORTEX
Here is my dissection. one big jpeg
Grum, you may find this painful, but I think you have some salvaging to do, if not total makeover.
http://www.filedropper.com/dissection
We need to... think widely, expect the unexpected, observe carefully, keep an open mind.
dvy1214
Even if one could build a perfect system complete with magnetic bearings, 96% efficient motor/gen set, vacuum, and tuned RPM of total system to individual motor/gen phase it doesn't matter how many pulleys or flywheels you add. What a flywheel provides in mechanical capacitance requires in energetic exertion to gain the purchase of x ft/lbs over x duration. In other words all a flywheel in an electrical motor/gen set buys you is time, just like in an internal combustion engine. And to address the pulley fantasies that I have seen pop up, just stop. FT/LB! FT/LB! FT/LB! all a pulley grants your is more feet for less pounds!
Notice you rarely see someone willing to put their energy device in a video for 2.5 hrs running a load in corner of a white washed garage with no conduits what so ever? I would watch every minute. But it won't be there because as far as I can see there are some very simple laws being looked over in every electromechanical "OU" device out of hope which gives way to human delusion. The greatest energy delusion, one that I have fallen into twice is the idea that parametric oscillation in some way shape or form is representing un-exerted energy or free balance. THAT IS ALL A CHAS CAMPBELL machine is. @tinman I commend you for pointing out the fact for people on parametric oscillation. In the Chas Campbell case, someone go build a 165 KW(220HP)(what a good automobile needs) version then hook it up to a 150KW AC motor and let me know how long it drives the car for before the flywheel can't buy it more time after you start it with a wall plug?
Not a neigh sayer, just probably want this more than you.
- David
Abt
Hi All,
I'm new here and did not read the whole thread. I coincidently stumbled over one effect I noticed on my very old lathe.
Look here: https://www.youtube.com/watch?v=0QCqqgc437I
This is definitely a flywheel effect. I had taken out the motor and checked it very precisely, it's just a normal induktion motor. You can read the amperage
on the meter (bit hard to see but possible). I noticed the effect when I was working on the machine just at higher speed, strangewise the rpm went up under load. Then I checked the amperage - it went down. It does not happen when I put the load on the outside of the chuck jaw, only when I brake it down in the middle. The bearings are old but in good condition, it makes no sense to me that the the wood could release them.
Thoughts are welcome...
Abt
gyulasun
Hello Abt,
I think the speed up of the lathe motor happens because when you brake the chuck on its middle (at the axle) part  you give a certain lifting force to the whole chuck, reducing its actural weigth a little so the motor senses less drag due to the less weight of the rotated chuck.
When you break the chuck on its outside jaw, the lifting force is missing but you now create an extra sideway force which causes an extra drag on the motor by actually hampering its rotation.
A friend of mine added: that is a babbitt bearing headstock as you can tell by the little covers where you put oil in... and belt drive. The force from the belt is down so he is lifting the shaft up, removing the downward force against the babbitt.
He would get somewhat the same effect when taking a cut as the material tried to ride upwards on the tool bit.
Gyula
Quote from: Abt on January 31, 2015, 06:01:59 PM
Hi All,
Abt
mscoffman
Quote from: MileHigh on January 17, 2014, 01:05:08 PM
Guys:
Satellites don't use flywheels for power.  If somebody believes that they should task themselves to learn about what they are really used for.
As far as I know this is correct. They are called reaction wheels. They allow precise repointing of the spacecraft around it's cg without using up any propellant.
Unfortunately, they are not very mechanically reliable. Batteries are much better. Space reaction wheel spin down as they do because spacecraft pointing is pretty
important to antenna alignment during the ecliptic time when they don't receive energy from solar panels.
