Using Chas Cambel Flywheel System For 15 Horsepower
Started by thankGod, June 25, 2012, 11:57:43 PM
Rafael Ti
Quote from: bugler on July 05, 2012, 04:05:50 PM
Wheels are bad batteries. Friction will stop them in a few seconds.
A well tuned good quality bicycle wheel can free-spin for 20 minutes or more and it weights only 1kg. So... could 1000kg wheel spin for 20.000 minutes?
Paul-R
Quote from: truesearch on June 26, 2012, 11:02:15 AM
1) Belt/Pulley loss: the energy-transfer in the diagram uses 3 belt/pulley pairs. This is a fairly high efficiency way of transferring energy
You, and others, are missing the point. The belt needs to have slack in it, and as a result, it jerks and snaps its way around. It is these bangs in the system which have an effect, the nature of which i do not know.
(Remember having to untighten a nut which is too tight? Get a spanner on it and it will not come off. Hit the spanner repeatedly with crisp blows from a hammer, and the nut may quietly drift off).
soltek
This system works by replacing AC gen with DC 12 volt alt from a car that 80amps then connect it to pure sinewave inverter say 4000 watts you can run a few of these then connect inverter back to ac motor to keep this system running (( For EVER ))) please use 100kg flywheel
this creates free energy
