Simple to build isolation transformer that consumes less power than it gives out
Started by Jack Noskills, July 03, 2012, 08:01:10 AM
0 Members and 50 Guests are viewing this topic.
TheCell
THe zip archive is splitted in 2 files because of the maxbytes limitation here in this forum.
The second part with the suffix txt must be renamed from
my_Replication01+.txt to [size=78%]my_Replication01+.z01[/size]
[size=78%]and you must download the first part in a previous post too : [/size]my_Replication01+.zip
Put both files in one dierctory doubleclick on the .zip file an here you go.
T-1000
Quote from: Hope on August 17, 2012, 07:31:11 PM
T-1000      I watched all those links in russian a few times    I understand no russian.   I see excited people and equipment and circuits.   I have a 1000Watt variac/ one constant voltage trafco 15 amps, one LARGE older neon sign DUAL trafco.   Can anyone make a finer detail schematic of the circuit for us?
Here is simplified circuit, hopefully it will be more easy to understand it now.
P.S> Ampmeter1 and Ampmeter2 will show different values in real life situation, you should seek for this condition first.
Jack Noskills
I got PM'd that report.zip is ok. Here is docx file renamed as doc so it will upload.
Jack Noskills
I will start high frequency experiments. I got PC, goldwave audio editor, audio amplifier that can spit out 260 watts of power, nanoperm toroids, and most importantly, lots of beer cause its friday. I might have a few ones if I am successfull. If not then down the drain it goes. So stakes are very high.
I try exact replication first, no fancy winds but just plain coils. With this method I don't think there needs to be power circulating, just power pressure.
Already played a bit, about 5 meters (50 turns) of wire on nanoperm at 15 kHz significantly lowers the audio volume, speaker is in series with the coil. If I put 560 meters of wire interleaved bifilar (several thousand turns), audio volume is much louder. This is fun stuff, and safe.
I will try this next:
First one coil, enough turns that nothing is heard when volume is at maximum. Then second coil, more turns so it steps up from 5 volts to 220 volts. I will try different waveforms. Maybe I get amps from audio amplifier and then volts from the second coil that runs the load. Load would then get amps and volts. Lets see what happens.
Hope
Quote from: T-1000 on August 23, 2012, 06:10:17 PM
YES! YES! YES!!  This helps a lot, thank you from the whole bunch of us T.
