Thanks to ALL for your help!!
Air Temp Nitinol
Started by gadgetmall, July 03, 2012, 10:08:49 PM
gadgetmall
 look at this picture . I want multiple wheels mounted on shafts for more energy output.the  difference will be using AIR Temp Nitinol and the heat will be the air and the cool will be the water .
gadgetmall
 another peculiar property of Nitinol: it can be bent repeatedly without showing signs of metal fatigue. And although Nitinol gets warm at the bend point when bent, like any other metallic alloy, it becomes cool when bent
back to its original shape.This metal is sounding more and more like somthing from outer space .. This is some more reading pertaning to this metal might actually have been from some of the encounters http://bragalia.blogspot.com/2011/07/roswells-memory-metal-air-force.html
gadgetmall
the best deal is the 40 foot roll $19.95 free shipping  .I have also ordered a 1000 foot roll of this particular wire . This is what is going to be the breakthrough in Cop > 1 . the wire has Incredible spring-back power . I made a small spring  and stretched it out and hung a vise grip on it and it lifted that heavy thing right up with some warm air. . i have uploaded a few experiments on Youtube . My Id there is 4Christonly1 .
Buy it here http://www.ebay.com/itm/Super-Elastic-Nitinol-Niti-New-Power-Technology-/330696040468?_trksid=p2045573.m2042&;_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D430386719976848579%26pid%3D100033%26prg%3D1011%26rk%3D1%26
i annealed a piece and it reacts with air and body temperature or hot water .
gadget
Mark69
Gadget, how do you connect it together to form a single loop, weld?
gadgetmall
Mark , with a Variable temp soldering station set to about 600f-to 750f and some Tin/silver solder . You have to scrape the wire to get the solder to stick because the wire has a slight oxide on it .they recommend a special Nitinol Flux  but i have soldered some without it using some acid flux and without .
I just can't believe the strength a small piece of this wire bent in cool water then placed near or in warm water . Its like a SNAP of the finger . you ever been thumped with a thumb and index finger flicked , thats how strong this is . It's tricky to make work because you have to anneal it first before you use it otherwise its simply a stiff piece of like piano wire you cant bend . well you can bend it but it just springs back to the original shape off the roll . you can run electric current thru it to get it to glow red while shaping it then in a split second dunk it in ice water . I do this maybe 10 times except i have used a torch lighter to get it red. then after that, make it cool and bend it then alternate to hot water . The Force actually increased 10 fold and set it to a lower transition temperature than the roll was supposed to have 125F. mine set to about 80degrees Fahrenheit and works really good in your hand or a warm room . This Nitinol has Power in it you won't believe . I am Glad the Department of Energy Declassified it.I believe this stuff is overunity in it self but don't quote me on it . the Guy that sold this also believes this to be true . WE need some who who can measure force verse temp to verify this as a calculation. This wire can lift 30 pounds almost 30 inches with a ~30 degree F change. i have done a small experiment where i made a crude coil spring 1.5 inches with a foot of this material and annealed it like above and it pulled up a pair of lock pliers with some air from a blow dryer almost instantly like 10 inches back to the spring length . the wire size is only .020"  . about the size of  the third  G string on an electric guitar. In ice water a small 1.5 inch piece bends in the glass from its own weight . wet noodle . but the instant you take it out the transformation begins to stiffen it to an unbendable Wire that just retains it's annealed shape.
