Air Temp Nitinol
Started by gadgetmall, July 03, 2012, 10:08:49 PM
markdansie
Hi Resin Rat
I agree with your comments, it is sad. Interesting material however looks like a lot of fun. Has a personality lol
Mark
gadgetmall
Hi guys . It's up to us to develop a useful device . The Oil Company s certainly don't want us to have free energy .  And they sure don't want Nitinol Motors that run from air temperature Differential that is a god given  everyday  occurrence. I like the pipe setup DreamThinkBuild rendered . As simple as it seems this could be put in your ceiling bathroom exaust fan holes and easily made to spin dc Motors which Charge caps or batteries and run lights . But I am building this to go in the Ground outside . I will have to use more than three sets of Wheels . I am using a Vintage erector set (Mecanno) and having a Blast Adding Pulleys and Loops of Nitinol . Once I get enough torque on My axle and maintain some Flywheels i should have a generator model working . I don't intent to leave my valuable Toys out side permanently to rust so Eventually Plastic Framing will be the way to go and Nylon and carbon Fiber axles ..The Nitinol Won't rust or wear out as it is Nickle and titanium .. Brass will turn green but stainless or aluminum pulleys won't . Been Thinking of using a BIG heavy flywheel i have off one of those Exercise Bikes . It has a Sprocket on it and once it is spun up by hand it only need a little help to keep it going . and it will rip your fingers off . I know i made a Bedeni magnet experiment with it and you cant stop it with the sprocket. Ok been Busy on several things and keeping My Little girl happy thru summer . It's winding down and about another three weeks school starts again for her  and Me.
Ok will let you see this contraption when i get the time . It has been Extremely HOT here in the east . Every day has been 110+ and ferocious Storms Nearly Every evening ,  There is certainly enuff air heat to run this . I just have to dig a nice deep hole for the temp differential of 25 degrees . 30-40 would be The optimum power.. still waiting for My No contact Thermometers to get a ground reading . I know its cooler in ground . the water well i have is freezing cold and condensates the pipes on the well motor and storage tank.. Ok any Ideas are welcome and i hope some of you grab some of this Stuff . The 40 foot roll is It . Not the "magic" 5 foot piece . I could not get that stuff cold enuff to bend . You need at least 29 degrees F to make it soft because at 32 degrees it still retains it;s shape . The good thing about the Magic 5 foot air temp or body temp wire is it is at its Maximum Strength at 32 degrees F and above ,, This might work in the artic or some place very cold . so 29 f and below it's martensite and 33f and above its full austenite .Looks to be only about 5-7 degree difference on "Magic" Wire . I can't use it .and don't have anything that cold until winter .. But thinking ahead when winter does come I se this outdoor system in reverse . the ground will be heat and the winter air Cold .It Might just work that way too.
Thanks Markdensie for the Video . It was refreshing to see a new Old one by the Man Himself .Mr. Banks.
Mark69
Been doing a little thinking, based on the original wheel with the two tubs of water.  Instead of trying to have it turn a generator, what about attaching magnets to the outside of the wheel (where the speed is the fastest) and have it passing through wire or whatever to generate electricity there?  Will it not generate more electricity that way?  Of course it could be updated to todays technology (neo magnets, etc).
Mark
gadgetmall
That would work fine and doable . i'll order some magnet . This will be good because no cogging if we use air coils .
Mark69
Right, and less moving parts means less friction and more power/speed :)
