Unipolar Induction - Relative motion isn't needed!
Started by gravityblock, July 14, 2012, 11:54:39 PM
gravityblock
Quote from: tinu on August 03, 2012, 02:55:40 PM
It is intriguing indeed!
However, 1/2 spin is just because he encircles the magnets counter-clockwise. The spin would have been different, probably 2, for clockwise case. Agree? (I’m sorry but I’m too tired and lazy to prepare a setup and check it exactly with a compass).
Best regards,
Tinu
I don't think the spin is different for the clockwise case.  Both a positron and an electron have a 1/2 spin regardless of their opposite spin directions (assuming of course they have opposite spin directions).  I guess we could say going CCW around the magnet discs would be a macroscopic display of an electron 1/2 spin and going CW around the magnet discs would be a macroscopic display of a positron 1/2 spin.  I ordered my magnets a few minutes prior to making this post and when they arrive I will try and duplicate this simple experiment for both the CW and CCW case.  Thanks for joining this discussion, and it's good to see someone else is intrigued by this experiment.  I do think this experiment shows an imbalance in energy around the magnet discs which can't be explained in having slight imperfections in the permanent magnets.
In one of the tests by Bayles demonstrating the chiral nature of the left and right sides of the magnets, the magnetic balance rotates 360o when the magnet discs are being rotated.  Slight imperfections in the axially magnetized PM's rotating on their axis could never show such a huge imbalance in energy on the different sides of the magnets.  In addition to this, the resonance occurs at the Schumann frequency of 7.83 Hz on the right side and at a frequency on the left side such that the difference frequency multiplied by the circumference of the disk magnets yield a calculated least quantum velocity equal to the square root of the fine structure constant in meter per second units. Since there is uniformity in the disk magnets strength and dimensions, and another pair of identical magnets demonstrate the same chiral energy difference between the left and right sides, it is herein postulated that the gravitational field of the Earth is creating the chiral standing wave around the disk magnets. Hence the 5 Hz resonance in test 5 as demonstrated in the movie. (5 Hz is 1/2 of the 10 Hz predicted in Bayles's unified field theory) located online at http://www.electrogravity.com
Also, the Magnetic Potential Vector (A-Vector) is proven to penetrate iron pipes with no measured loss in this A-Vector test by Bayles.  The A-Vector's ability to penetrate iron pipes with no measured loss is a good explanation in why an increase in current and voltage in the behemoth pickup coil(s) are close to equal regardless of whether the core is iron or air.  This phenomenon is due to the A-Potential, and not because there may be slight imperfections in the permanent magnets.
Gravock
