Jeff Cook Paper
Started by DreamThinkBuild, August 01, 2012, 01:56:58 PM
DreamThinkBuild
Hi All,
Jeff Cook has a new paper titled "Experiment on the Linear Increase in Efficiency with Multiple Moving Magnets over Pulsed Inductors".
QuoteAbstract:
I have prepared an experimental apparatus consisting of an inductor and five reversible DC motors, used as DC electrical generators, hooked to ring magnets suspended above the inductor whose radii are ninety degrees from the radius of the inductor and hooked from belts to the motors. I then DC pulse the inductor causing the magnets to experience three motions, but confine all energy with the belt to the rotational motion alone, which turns the motors. I include many iterations of varied waveforms and different numbers of generators in order to measure the power IN to the inductor and OUT from the reversible DC motors, used as electrical generators (not hooked to the same electrical circuit with the inductor in any way). I have measured over many iterations and varied resistive loads (though only a ten Ohm load is described in this paper for sake of straight forward simplicity) that the COP (the coefficient of power OUT divided by power IN) is greater than unity of significant magnitude when the amplified signal frequency input to the inductor is above a certain threshold, while the power IN is reduced below another threshold.
source/pdf: http://www.worldsci.org/php/index.php?tab0=Abstracts&tab1=Display&id=6483&tab=2
Not sure if a thread was created for this yet but it looks interesting, have to study it some more.
Looks like he is also making a new toy "Zeta Trax" which can magnetically launch a toy car, how much force or angle change you need to create this effect is unknown.
Link to video:
http://www.youtube.com/watch?v=SLJDQwHnItA
I don't know about his paper.... I'll have to digest it thoroughly and see if it's nourishing or not.
Meanwhile his little car and trax thing is very old news, and even so he seems to miss some critical points about the "effect".
He also makes the very clear claim that there is no back-reaction or "recoil" on the ring magnet as the car goes shooting out the other end.
My own experiments indicate otherwise. If he is in error about this simple empirical fact.... it's going to be very difficult for me to accept any further claims of unusual behaviour or measurements from him.
And, even before reading the paper, I will make this prediction: He claims significant and repeatable output energy greater than input energy... but his device still needs a power supply to run. I'm always happy to be proven wrong, with repeatable empirical demonstrations and checkable outside references, of course.
http://www.youtube.com/watch?v=nUihboGkJnE (this is a remake of a video I shot and posted in 2008)
http://www.youtube.com/watch?v=C69a28Jpmec (made just now in response to Cook's claim of no back reaction)
DreamThinkBuild
Hi TinselKoala,
Thanks for those links and the new video. I do see the recoil, I re-looked at his video but it's hard to see if a recoil is present due to small car model, his hands are pushing on the lever arm and large wide base from which it is launched.
His magnet seems to to get stuck in the middle not pushed to the outside. I think I see how he is doing it now. Both magnets are parallel to each other. One is south facing the other north. It gets pulled in and when the other magnet turns 90 degrees it gets forced out. You can see how the car starts to twist at 1:30-1:31 in the video but it's locked in that round plastic channel so it can only be pushed out instead of flipping around.
As for his current paper. He needs to run from an ultracap bank and feed the outputs to charge it. I think that is the only way to validate a device. Never use batteries, each one has a mind of their own.
Quotebut his device still needs a power supply to run.
I don't think you can get any machine to work that doesn't require an input source. Even biological systems need to eat, that reminds me pizza is ready.  8)
Quote from: DreamThinkBuild on August 01, 2012, 06:31:26 PM
Hi TinselKoala,
Same is true for the config I show in the recent vid. The magnet wants to flip around but the tube prevents it. Depending on which way you have the projectile / car magnet oriented, the stable positions are different, but the recoil on pushing thru is there. I think the only difference with his car is that the relative "lengths" of the magnets are different from mine: I use a cylinder projectile and I think he's using a disk in the car. This means that the "lock" position for his car will be very narrow and not very "springy" which may be why he's not noticing the reaction. With a longer magnet like I use the lock position is much deeper and requires relatively more force to exit... and thus returns more stored energy when the magnet finally does pop out.
Agreed... but if you've got one machine that makes more output than input, yet it still needs some input... that's not really much of a problem. Make 2 machines. Use the output of the first one, filtered however necessary, to run the input of the second one, and the output of the second one then runs the input of the first one. If you are claiming huge amounts of OU like 17 or infinity.... then even a very INefficient conversion process between units would still make possible a self-running loop of several devices. If I can boil water with 17 times the efficiency of DC current... then I can EASILY run a steam powered generator, with overall efficiency of a miserable 10 percent, and still wind up with plenty of electrical power output to feed another COP > 17 boiler/steamengine/genset.
The problem lies in getting that little bit of COP>1 in the first place. If it's really there it will show up in many different ways, not just wiggly lines on an oscilloscope. For example the Steorn magnet motor, claimed to add something like 10 Joules of mechanical energy for each magnet passage based on instrument readings, should have accelerated on its own, since the power dissipation of the rotor was known to be quite a bit less than that and the mechanical energy should have accumulated, speeding up the rotor. But it did not....
So if Cook is claiming this robust, repeatable, significant amount of energy out in excess of energy in.... if it's real he should be able to demonstrate it unequivocally with some means other than numbers and squiggly colored lines.
As a thing is viewed so it appears. If what one is seeing appears to violate some long-held established principle that's intertwined with everything else we do..... then one really should carefully re-evaluate what one is seeing... and perhaps look at it a different way.
Lakes
Measure the amount of push (or pull) with a weight measure attached to both ends of the magnet, should be equal, no?
