My Invention
Started by johnny874, August 11, 2012, 10:59:31 AM
johnny874
Quote from: AB Hammer on August 22, 2012, 10:20:12 AM
To set a story straight. Most of us will not work with James Lindgaard either. But I do wish Jim the best of luck.
Alan / AB Hammer
PS- Yes Jim, I am still around. I just don't post much due to I don't have the time with all the reconstruction going on.
oh, alan, remember this post of yours ? Saying my medical problems make me a fraud ?
But you say that is not slander, it is and something I shiold sue you for.
http://besslerwheel.com/forum/viewtopic.php?t=4656
johnny874
  zoelra,
this was an idea I helped webby1 (Tom) develop. Not sure why he lost interest in it.
But now that I know tk and others are messaging each other about me, not sure what all
they're up to.
But you might find this idea interesting. it's funny though, when I'm done with Bessler's
wheel, i might not make it known. To much hate surrounding it.
http://www.overunity.com/12337/webby1s-pendulum/
zoelra
Hi James,
Sorry for not posting earlier.
Last night I was able to make some additional videos which I will now try to explain.  In order to use the same weight for the counter weight and pendulum bob, I had to move the counter weight out 6 inches so that there was sufficient torque to pull the lever back down after the pendulum swing.  I also added an additional mount so I could swing the pendulum and mark how high the main lever rose (on the counter weight side) when the pendulum was at the bottom of its swing.  I drew a line on the main lever to indicate the initial drop position of the pendulum lever relative to the main lever.  I also added a line on the opposite side of the pendulum pivot point which represents where the pendulum lever should stop after its swing (same height as drop height).  After measuring how high the pendulum lever actually rose, the difference would be the height the reset mechanism would need to lift the bob.
Interesting enough, the main lever did not drop (or not by much) by the time the pendulum bob came to a stop at the top of its swing on the inside position.   This is what is shown in the first video (f1).  In the second video (f2), I lowered the camera to a position that was level with the top of the pendulum bob when it came to a stop at the top of its swing on the inside position.  I put a piece of blue tape on wall behind the pendulum, and after a few test swings, I marked the top position with a black line.  I then connected a cord to the main lever and the pendulum bob so that when the main lever was at the top position, the pendulum bob would be at the actual position it came to after its swing.  This is what is shown in the third video (f3).  I also attached a picture which was a slide out of f3 that shows how high the pendulum rose when the main lever was at its highest position.  On this picture I marked in red the drop and ideal raise position of the pendulum lever.
Well from the videos you can see that the pendulum does not return to the same height (or relative position against the main lever) from which it was dropped.  You can also see that the reset mechanism does not fully reset the weight.  By moving the cord further out along the main lever, the distance it travels vertically may allow the bob to be raised further.  More testing is required.  I think the results though are position and worth thinking about.  Also keep in mind that I did not use bearings so the main lever and pendulum bob did not raise as high as they could have due to increased friction.
Rick
zoelra
2nd and 3rd video and pic
zoelra
I think I need to clarify what I said in my previous post.  The attached picture (f2-slide) is taken from the second video (f2) when the pendulum bob has come to a stop at the top of its swing to the inside.  At this time, the main lever is also at its highest position.  Note the position of the pendulum lever relative to the main lever.  In the third video (f3) a cord has been added to link the pendulum bob to the main lever such that when I lift the lever to it's highest point, the pendulum bob is also at its highest point (as determined during the swing test in the second video (f2).  When I let the lever drop, the bob is raised, but not to the initial drop position.  In the video I manually show how high it still has to be lifted.  Open the third video and place it just above the pic so you can still see the pic.  You will see when I lift the lever to the top position, it resembles the arrangement of the levers in the picture.
By positioning the cord attachment point out further along the main lever, this will increase the amount of cord pulled and will lift the bob higher.  Of course the counter weight may have to be moved out further as well or made heavier to counter the increased torgue due to moving the attachment point out further.
