Richard VIALLE's new theory about negative mass and overunity
Started by Pascuser, August 28, 2012, 07:03:17 PM
Khwartz
Quote from: Khwartz on January 26, 2014, 12:59:32 PM
Here they are!  :) the specifications for the basic replication: the "U" shape = the most documented one and the one who has produced "the electrical incident", as Pascuser call it, or "the power avalanche" (or just "avalanche"), as I call it - the original straight one has too produced the avalanche (with up to 1 m long of spike voltage) but less studied until now. (Thanks to BlueDragon for his comments I have "freely adapted" for the publication here :) ).
Sorry, couldn't correct it in the original post: it is 8 cm long spark, not 1 m.
8 cm of spark would mean: 8 cm * 30 kV/cm = 240.000 V in dry air and in 50 Hz. (Without power consumption but feeding the initial source of power.)
tim123
I've completed the first stage of my build. Image attached... :)
- The coil is on a 350mm pipe. It's 0.63mm wire. So it's about 500 turns. Hope it's not too much...
- The 2 cores are 15mm copper pipe, with end caps & brass bolts soldered to the outside ends.
- On the inside the have loose end-caps, with rubber washers stuck on.
- The white PVC tape on the copper tubes is a spacer - to hold the tubes in the center of the coil tube
- The 2 ferrite cores fit into the pipes spookily well. (Note, I can run the tubes with or without them...)
I've tun out of time to test them today. Hopefully will be able to start playing tomorrow.
tim123
Quote from: Khwartz on January 27, 2014, 07:40:56 PM
Sorry, couldn't correct it in the original post: it is 8 cm long spark...
Hi Khwartz :)
  I totally didn't get that before... 8cm would be, as you say, a lot of volts! I might need more insulation between the tubes... Will have to see...
Do you do experiments? Any chance of a Khwartz replication? :)
Regards, Tim
Khwartz
Hi tim123.
Not sure if you ask me questions or if you ask help or advises from me.
As I could have understood you were not about to grant me enough credit on my ability to understand what you write nor the knowledge or understanding I can have on Richard's Autogenerator. So, could you specify to me your position, please?
Regards.
tim123
Hi Khwartz,
  I thought that you weren't going to give me credit for having my own ideas, as you just dismissed my first idea... :(
I spent some time thinking about how the coil may act as an antenna. I thought that it might be important. I did the calculations, and i shared my idea in good faith, hoping that you would discuss it with me. But instead you said:
QuoteI very understand your idea.. No need to ask him, you may do it like this...
And you just repeated the normal build instructions... So it seemed to me that either you a) missed the point what i was saying, or b) you thought my idea was stupid. I was disappointed by your response...
Note - it is *because* i value your opinion, that i was disappointed...
I don't know if the length of wire in the coil is important, but I would like to be able to discuss this, and other things with you... I would hope that you might also do a replication, so we can compare notes...
I do value and respect your opinion, and i hope that is mutual. I hope we can work together on this and have some fun, and learn some new things...
Regards, Tim
