Richard VIALLE's new theory about negative mass and overunity
Started by Pascuser, August 28, 2012, 07:03:17 PM
verpies
Quote from: tim123 on February 17, 2014, 01:38:04 PM
Hi Verpies. Why an even number of layers? Why would that make a difference?
To cancel the circumferential current.
Notice that as a toroidal winding advances along the circumference of the toroidal core, the current advances with it, eventually forming ONE LOOP of current around the core's major axis.  This current creates magnetic field that is perpendicular to the plane of the toroid, and as such it is not contained within the toroid (and it must close through air).
Quote from: JL Naudin
In a common toroidal coil, each layer is equal to a "one turn coil" whose axis is parallel to the axis of the toroid. So, one layer of toroidal coil is equal to a flat coil of one turn and thus it can tap or produce EMF outside the torus.
So if you have 100-turn classical winding that spans the entire circumference of the toroid, then this winding acts like 1 turn of wire along the circumference of the core, in addition to 100 turns of classic toroidal windings.
There is even this patent that's centered around this issue.
verpies
Quote from: tim123 on February 17, 2014, 01:30:26 PM
- 15v on the gate from power supply #1
Is the 15V power supply to the gate driver stable?  Is it bypassed with close ceramic capacitor close to the driver?
I know I need to add a snubber first... I will probably just connect a diode in reverse across the coil to start off with...
Snubber is necessary only if you interrupt the current trough the coil.  If you do and if you do not snub the resulting voltage spike (or feed it back to the power supply with lossless clamps) then this spike will kill your transistor or interfere with its switching.
verpies
Quote from: tim123 on February 17, 2014, 02:19:26 PM
Ok, it's not yet perfect... It's not giving me a clean square wave output above about 100KHz... Above 400KHz - there's no waveform - but there is still power going through...
I'm guessing that the resistors between the driver & gate are too high value at 48Ohms... (Verpies?)
Maybe.  Show me the voltage waveform between the gate and the source of the MOSFET and I will be able to reply with certainty if that is the problem.
Khwartz
Quote from: tagor on February 17, 2014, 06:39:57 AM
yess it is very important , see the MEg and the BITT
and on conspi the LABO work
But for the "conspi the LABO work": no more access since an argument with Pascuser ;)
tagor
Quote from: Khwartz on February 18, 2014, 07:04:19 AM
Oooooooooooh yessss
can you change your IP ?  (it is more than five years of works )
