Free Energy Magnet Motor ?
Started by johnny874, August 31, 2012, 10:24:35 AM
I actually have a font installed for that? Who knew.
Pan yuming
This is Chinese Font.   Google Translated:
Figures 1 and 2 essentially the same, the same principle is true, I just improved this machine, just refer to the other types. Figure 1 Figure 2 motion was as smooth.
Many people say that you can succeed.
More successful people Mdl415 said: "My machine well, with a 12 magnets, magnet spent less than $ 60, spent a total of 400 yuan. Mounted on the bike tried, now run about 200 km , the mountain dirt road also ran more than 10 kilometers, climbing is also no problem, speed is probably 40 veins, did not run too fast, dynamic okay. "
I also play with a little simple magnet and iron tablets, indeed, there is no guide disk size is much less repulsive, Me!
Others did not say we do not know the structure, will not care, they learn out in Figure 2 of this publication has become well-known structures.
I is the main changes its reciprocating motion to rotary motion. Analog car piston engine and rotor engines.
Imagine moving magnet of Figure 2 that do not move up and down to the level of the left. You can also have the power to exercise it, the power of the size of the first matter, just look at each position of the magnet movement between the force comparisons as well as the sum of each position and force. If you toward a certain direction is greater than the sum of the other direction, it can automatically turn up.
Then draw a diagram, reflecting the imagined situation, examine imagine correctly.
Then draw more sets of the same magnet system all together, if you can, put them in sets of magnets arranged in a symmetrical circle. If you can, OK it.
Good on the map! Figure 3 is it!
Pan yuming
In the drawings:
Red boxes represent the N-pole permanent magnet, blue represents the S pole permanent magnet.
Yellow is the magnetic soft iron.
Counterclockwise rotation of the inner rotor is a permanent magnet.
The outer ring has a fixed permanent magnet stators.
White is made ​​of soft iron magnetic sheets. It rotates clockwise at the same speed with the rotor in the opposite direction, the position-related, that by positioning gear.
gif animation map is rotated 16 steps, each step rotated 3.75 degrees.
Figure carefully each step, see the rotor, guide disk, the gravitational repulsion relationship between the stator estimated size.
The force is greater than the estimated favorable unfavorable, you can turn up friends.
Because there is no input, just be able to turn that over a (overunit) friends.
This moment,
The 1st arrow at the far right red and blue magnet with suction to pull the white guide disk rotates clockwise.
2, the arrow, the magnetic field lines can not penetrate magnetoconductive here basically balanced.
3 arrows, guide disk is still blocked off move, given two blue magnets.
4, arrows, left upper red blue magnet by several magnets attract, blue magnet with the force rotating counterclockwise.
5 arrows, intermediate rotor magnet remains red red magnet stators being thrust right to counter-clockwise motion.
6 arrows, some intermediate rotor magnet red blue magnet by the Fang Dingzai attract positive force to rotate counterclockwise.
All valid reaction force greater than the force.
There 8,9, A, B, C, D, E, 7 can be gradually analysis dpi. My conclusion is: can automatically rotate.
LibreEnergia
Quote from: Pan yuming on July 11, 2013, 11:06:38 PM
My conclusion is: can automatically rotate....
No it won't.
Using a bit of mathematics, (specifically Noether's theorem ) one can state with absolute certainty that there is no possible physical arrangement of permanent magnets that can give rise to continuous self rotating device.
Pan yuming
Thank you LibreEnergia !
Yes, I know. According to conventional physics, perpetual motion is impossible; Output more than input  impossible. But this forum why it is called 'OU'? :)
Why do not I try to do the prototyping? I have not material.
Thank you google.
