REAL WORKING MAGNET GRAVITY WHEEL !! It WORKS !!
Started by gadgetmall, August 31, 2012, 09:56:40 PM
Bruce_TPU
Quote from: WilbyInebriated on September 02, 2012, 04:28:15 AM
no kidding!  reminds me of that tinselkoala/alestalokin guy and that 'whipmag'...  ;)
Wilby we AGREE on something!!  Big hug!
Bruce
johnny874
Quote from: gadgetmall on September 01, 2012, 04:59:46 PM
Quote from: Pirate88179 on September 01, 2012, 04:26:27 PM
Al:
That video of the guy flying is incredible.  I hope it is not faked somehow...it looks real to me.  Humans are not supposed to be able to make enough horsepower to do that...although, I think it was the Gossamar Condor pedaled powered plane flew like 20 years ago and that was not supposed to be able to happen either.
This video was all over the news several months ago .
He has a webaite and you can probably  buy those birdwings and fly !! Oh coarse someone will say it's fake and we all know that we as experimenters won't believe it till we do it ourselves:)
here's how he did it . it started out as a Dream .
The heart of the system is an Android smartphone. It processes Jarno's arm acceleration and computes the corresponding motor output. The phone is connected to a Seeduino ADK microcontroller, which connects to two Wii Motion Plus and a Wii Nunchuck. These are used to measure the acceleration, motion and all the different parameters required for making the calculations needed for the wing flapping.
After his first successful test, Jarno is ecstatic:: "I have always dreamed about this. But after eight months of hard work, research and testing it all payed off."
Horsepower is just a matter of pulleys like we can lift 1000's of pounds with the help of a couple of pulleys and some rope.If you have ever seen an albatross try to fly and do it then you see it takes big wings to lift that heavy bird.iI have seen them on the beach run and stumble and roll and then run again and take off.
this was an early prototype here  . very cool But They said it was FAkE and an experiment for a Movie TRixTer!
Seems To elaborate for a prop in a low budget movie but look like they tried andd failed so why not make a movie instead .
http://www.youtube.com/watch?feature=player_embedded&;v=TH3fQbGlQlM
  gadget,
there might be a way to make wings work. Only lift a part of the wing and lift it at an angle.
Then when that part of the wing is pushed down, it would have air underneath it which could flow outward under the wing creating more lift.
This would allow for the possibility of using leverage to get more work out of a downward stroke.
If you watch birds fly, they don't lift the tips of their wings, probably saves a lot of energy that way.
I think that's how the Wright Brothers got their plane to fly. They saw how a bird's wings worked and allowed for the wings on their airplane to twist. Before that, all wings were made of a rigid design.
Today, they are now called wing flaps and ailerons.
        Jim
Paul-R
Al:
I'll bet it is.
Calculate the horsepower needed to get that amount of weight up, to displace
that amount of air with such an inefficient device. There is no athlete who
could achieve it.
It reminds me of the human  powered flight competition using an efficient wing:
http://media.aerosociety.com/news/2012/07/24/raes-human-powered-aircraft-icarus-cup-lasham-gliding-club-%E2%80%93-results/6315/
kampen
gadgetmall
yea another inventacom experiment , The humanbirdwinds were all over the networks and had everyone fooled . Still it migh be possible one day with the right motor .Now i know Lasersaber Flys anytime he wants with his self made paramotor (100cc electric with lifopo battery packs and a big prop on his back.
) and that thing he can strap it on his back and literally lean backwards and thats fan will  hold him up from falling backwards with his weight on it ..A para sail is the best way to fly and no pilots licenses needed !Strap some bird wings on that baby!
