"solid state free energy device" - rebuilt it but unsuccessful
Started by Teunis, September 02, 2012, 05:41:07 PM
gauschor
Really strange, I agree... I wonder if it only works at this specific place or not. I find interesting that he says, it didn't work with otherwise shaped magnets. I'll dig through the video comments to look if he has...
Just guessing, maybe he accessed the "Schumann frequence"... (don't know if this makes sense or not :p)
TheCell
@Teunis
visit him , you both live in the netherlands.
I tried 2 setups like these. The HD magnet is glued on a frame , so I put the coil a near as I could. With no success .
The coil which is connected at the middle reminds me of a trawoeger pyramid .
This coil was shortened until resoance occured.
Why is dc instead ac generated . My theory is that a permanet particel flow is guided through the magnet through the coil . (Whatever that may be) No trafo can generate dc because of the max flux limitation. The magnetical flux must steadily increase for gen dc.(Which cant be). If it's a fake it's well made. Meet him to get the knowledge or otherwise to stop him posting nonsense.
People....please.
If what you are seeing appears to violate known principles, then you probably...with a high degree of probability... are misinterpreting what you are seeing.
You could be misinterpreting for several reasons, among them deliberate deception or illusion on the part of the person who is showing you what you are seeing.
If you will look at the other videos from this same person, you will find another video showing a motor driving another motor, the first one being powered by the generator effect of the second motor being driven by the first motor. There are also some random coils and things in that device too.
http://www.youtube.com/watch?v=f0fwjY6_-1M
The presenter has explained and illustrated that that device was made very simply: by taking apart one of the motors and putting in some button cell batteries where that motor's armature and magnets used to be. A small stub shaft to complete the illusion and you are ready to go.
Now... bearing that fact in mind. please look again at the video being discussed presently, and tell me if your interpretations of what you are seeing are still the same.
What is more likely.... a concealed battery _in the motor housing_  or that a coil and magnet as shown could power a motor?
Now, I've shown real wireless power transmission making a DC output that drives a motor, that in itself is not too difficult to do .... but I have to use a couple of capacitors and a fast diode in the receiver in order to make the AC power it receives in its loop of wire into the DC that the motor wants. The simple coil or two of wire, and the magnet, just won't do it alone.
Tito L. Oracion
hi everyone  ;D
That thing is fake, and that is easy to do.
the coil is a continuation of the two button battery in series  inside the motor.  ;)
notice the white tie to join the two pieces because it is not fit anymore. because of the battery.  :D
can't you see how easy to make fake free energy device using only two thin 3v button bat?  :o
in making free energy using radiant energy, you should do it in phase by phase and that is stepping it up little by little.
that was what tesla is saying about the stone ice  into an avalanche.
and that was also the technique used by moray ok?
The secret is coiling  8)
;D
TheCell
@Tito
he measures voltage without the motor, even if there were batteries installed in the motor.
So maybe he faked it , but not the way you described.
