Thanks to ALL for your help!!
A truly interesting transformer overunity concept
Started by leviterande, September 03, 2012, 11:18:01 AM
leviterande
I dont understand why people are seeing that the "MEG" has some potential while not  seeing that a traditional iron core electromagnet is also having  some phenomenal  potential as well (if you want to see it that way).  Let me explain, The whole concept of flynn/Radus MEG is that you turn off the magnetpower with a power seemingly  less than  that of the magnet itself. in the case of FLynn the  total force is 3700grams   from which is 1100 grams  that you pay for coming from an electromagnet. so you are using 1/3 of the power  to  gate the magnetic flux which seems to be a key to overunity. I thought it to be  the final key to overunity until  a extremely simple thought hit me: an  iron electromagnet is in fact much much more effective..  how? well  for a single simple iron core el.magnet you are also only putting a 1/200th of the  power!!! to power and control the electromagnet. In the flynn MEG you  use 1100grams out of 3800 which is roughly 1/3 of the power..  you see where I am going?
Im not sure if I am absolutely right or  if my   meaning didnt go through, but your explanation to why  my original iron-core-aircore theory wouldnt work SHOULD precisely  apply as well to  the flynn device.
Thanx
cristache
Problem is: can you keep that power level constant and less than you draw from the system?
I would say PM have more potential since the power density they have and you don't have to put your own energy into them.
But then again is difficult to avoid Lenz law and the fact the magnetic field is conservative - loop integral of the work (force by distance) is null.
The moment we figure out how the make the field non-conservative within a certain configuration we get the overunity, or more correctly put we get the energy from the magnet.
leviterande
ionizer
You need coupling between an external source.
Not overunity but it can be free energy in that you don't have to pay for it.
But don't think some hooptie dooptie core will magically start to deliver energy i't won't happen you need an energy source power has to come from somwhere.
