HEAT and Hydrogen at a same time and efficiently
Started by wizkycho, September 05, 2012, 11:48:43 AM
wizkycho
Hi all !
we have seen this
http://www.youtube.com./watch?v=8n5sSmJsCdY
cause of eddy currents water is heated but allso rotating disk is slowed down and sistem is underunity.
What would happen if rotating disk (with magnets) is below plastic (nonconducting material) vessel
filled with water and added iron (or some conducting) powder ?
1. generate HEAT
2. dissociate water (cause of generated currents in iron particles)
3. will the system exceed 100% efficiency
(I think that generated but dislocated electrons would less or not oppose to rotation of disk and system could go OU)
can someone make experiment and/or contact author of video to make one.
(at a moment I have some issues with google account)
Wiz
wizkycho
Hi all !
Can please some conduct above proposed experiment (and film it) but instead of rotating disc w. mags use induction cooker.
Vessel should be glass or plastic so only iron powder is reacting to magnetic fields from cooker.
I don't have induction cooker nor have prepared rotating disk with Perm. magnets.
If we get hydrogen or heat or both then replacing ind. cooker with rotating perm mags.
will produce hydrogen and/or heat on demand with very high COP
cause small particles of iron induced Lenzs fields are not likely to have same vectors so will not oppose to rotation of
rotating mags. that have much larger fields.
Please someone do this experiment
profitis
Exellent thinking sir.you may also want to try in caustic soda sol for a result (?)
